What is the besy way to de-gunk sticky metal drawer slides?
Forum topic by Toolz posted 05-31-2013 08:41 PM 4578 views 0 times favorited 9 replies Add to Favorites Watch
View Toolz's profile
Toolz
1004 posts in 3983 days
05-31-2013 08:41 PM
A couple of the drawers of the chest I bought have metal slides in the base that are sticky. I thought about spraying some WD-40 in a plastic bowel and then either use cotton swabs or a flat screwdriver tip wrapped with a piece of rag to try to clean them out and lubricate them at the same time. Even with reading glasses I don’t see that well and am not sure how to release the slides to completely remove the drawers. Any other suggestions or tips will be most kindheartedly welcomed.
-- Larry "Work like a Captain but Play like a Pirate!"
9 replies so far
117422 posts in 3818 days
#1 posted 05-31-2013 08:55 PM
If you can soak or wipe them down with some naphtha or lacquer thinner. Many metal slides have a black tab or trigger you pull or push down to get them to come apart.
Toolz
#2 posted 05-31-2013 09:59 PM
Thanks Jim. I have some Naphtha and will try to release the tabs to remove the drawers. Much appreciated.
View richardwootton's profile
richardwootton
1701 posts in 2196 days
#3 posted 05-31-2013 10:02 PM
Some brake cleaner might work also. I know it dries really quickly, I just don’t know if it will discolor areas where it comes in contact with the wood.
-- Richard, Hot Springs, Ar -- Galoot In Training
Toolz
#4 posted 06-01-2013 12:11 PM
Thanks Richard. It is a Gerstner wooden chest and I definitely don’t want whatever I use to come in contact with the wood.
View MrRon's profile
MrRon
5277 posts in 3485 days
#5 posted 06-01-2013 04:18 PM
If you can release the drawers, you can then remove the slides. You can then clean them without risking damage to the chest.
Toolz
#6 posted 06-02-2013 02:43 PM
Thanks Ron I will give that a try ;-)
View shampeon's profile
shampeon
1899 posts in 2425 days
#7 posted 06-02-2013 03:06 PM
I’m restoring an old Craftsman tool cart currently. I removed the slides and soaked them in Simple Green before scrubbing them down with a bristle brush.
View waho6o9's profile
waho6o9
8539 posts in 2818 days
#8 posted 06-02-2013 03:11 PM
http://forum.gerstnerusa.com/forum.php
Maybe the Gerstner forum can shorten the learning curve
for you.
HTH
Toolz
#9 posted 06-03-2013 03:34 PM
WOW, Thanks waho6o9 I have it bookmarked now!
