Finishing aromatic cedar
Forum topic by Paddywhack posted 05-30-2013 08:00 PM 2663 views 0 times favorited 6 replies Add to Favorites Watch
View Paddywhack's profile
Paddywhack
7 posts in 2459 days
05-30-2013 08:00 PM
Topic tags/keywords: aromatic cedar finish
I have two book matched slabs of aromatic cedar I’m turning into a table. I’ve never worked with this wood before. Anything I should know? I’m wondering what the best finish is for this type of wood. I like a satin or matt finish.
Cheers
View Finisherman's profile
Finisherman
227 posts in 1722 days
#1 posted 05-30-2013 08:37 PM
Is the table going to live indoors, or is it going to be an outdoor picnic table. If the table is going to stay inside, then you can use pretty much any finish you want, from shellac, to varnish, to lacquer to waterborne. If this table is going to be used as a picnic table, then I’d steer away from finishes which for a film, like spar varnishes. These finishes won’t hold up to rain, snow and intense sunlight for very long, in spite of what the label tells you. Trust me. I once had to scrape and sand a layer of peeling spar varnish off of a cedar picnic table. Not a fun project. I think that you’d be best to go with a finish which can be recoated easily like an oil varnish blend, preferably one like Deftoil exterior wood finish. Of course, you could also use a semi-transparent exterior deck stain.
View rrww's profile
rrww
263 posts in 1986 days
#2 posted 05-30-2013 09:43 PM
For indoors I spray my aromatic cedar with stain lacquer. I love it!
Good luck!
View Grandpa's profile
Grandpa
3259 posts in 2548 days
#3 posted 05-31-2013 02:40 AM
Linseed oil to bring out the color then I have used Lacquer but I think Poly is tougher.
View Jim Finn's profile
Jim Finn
2595 posts in 2795 days
#4 posted 05-31-2013 09:32 PM
I use Tung oil finish on cedar boxes. Wipe it on. Shellac and sand it first though. Cedar will absorb a lot of finish so the shellac helps seal it.
View Jeff in Huntersville's profile
416 posts in 3067 days
#5 posted 05-31-2013 09:44 PM
I’ve used both poly and shellac. But you lose the cedar odor.
View pintodeluxe's profile
pintodeluxe
5544 posts in 2686 days
#6 posted 05-31-2013 09:44 PM
I have never seen a table made of aromatic cedar. Projects I have used it for went unfinished, to maintain that pleasant smell. It is pretty soft wood.
