Record jointer plane redux
Forum topic by oltexasboy posted 05-30-2013 06:41 AM 1022 views 0 times favorited 2 replies Add to Favorites Watch
View oltexasboy's profile
oltexasboy
11 posts in 2133 days
05-30-2013 06:41 AM
Topic tags/keywords: plane joining question cedar
Ok , so I took a cutoff 24” section of a steel framing square, drilled and tapped the side of my jointer plane in order to have a good square edge attached to my plane.Veritas sells a version of this squaring edge for their planes so I figured I could do it myself instead of spending $250.00 for a new plane. This obviously is to keep the planned surface(jointed edge) square with the face. Ok ,now here is my question, should I try to plane from both ends toward the middle in order to prevent snipping the end or will it make a lot of difference either way? I hope some of you guys have more experience than I and can tell me what you think. I am making a aromatic cedar chest for my wife and there is a lot of edges to joint,could use a little help.(by the way all this lumber is rough cut.)
2 replies so far
View Don W's profile
Don W
18684 posts in 2529 days
#1 posted 05-30-2013 11:37 AM
veritas sells a jointer fence for your jointer. and no drilling and tapping.
To answer you question, I typically follow through on each stroke. You shouldn’t get snipe if you hold the plane true, but do what works for you. Working from both ends can help keep a consistent width, but follow through from both sides.
It also depends on the piece. Its more about the grain direction than anything else.
oltexasboy
#2 posted 05-30-2013 04:37 PM
Thanks Don, I do as you say with the follow through,I also believe that to be the key. I also picked up the url for your rss feed, good page, again thanks.
