Please, help me identifying this hand plane.
« back to Hand Tools forum
Forum topic by jackcamino posted 05-29-2013 08:12 AM 4214 views 0 times favorited 19 replies Add to Favorites Watch
View jackcamino's profile
jackcamino
21 posts in 2318 days
05-29-2013 08:12 AM
I just received this plane I bought on ebay. This is intended to be an user plane, not a collector but, it would be great to know what I got.
I took some pictures and I would also like to give a description.
- 9 3/4 length.
- 2 7/16 width.
- 2” blade.
Well, I couldn’t figure out how to attach pictures so, more description.
- lever cap Stanley on red, kidney hole Pat no. 1918750 on the back, and the rest doesn’t say Stanley or I can’t read any other brand behind the rust. There is definitely something on the top of the blade.
- Made in USA behind the front handle and a kind of wall that separates the opening of the blade.
- round hole on blade closer to the sharp edge.
- frog has 409 number.
- the part that receives the frog is like a “HH” basically, a horizontal crossed by 3 verticals, 2 on the sides and 1 in the middle.
I would like to post some pictures if someone also guide me in the process.
Thanks,
Jack.
-- When you think that I am buried and I will revive. (folio 59ii RECTO). Codex Atlanticus. Leonardo da Vinci. c.1490
19 replies so far
jackcamino
#1 posted 05-29-2013 09:07 AM
!/Users/jackcamino/Pictures/iPhoto Library/Originals/2013/May 28, 2013/DSC05452.JPG!
!/Users/jackcamino/Pictures/iPhoto Library/Originals/2013/May 28, 2013/DSC05459.JPG!
!/Users/jackcamino/Pictures/iPhoto Library/Originals/2013/May 28, 2013/DSC05462.JPG!
I hope this works.
View LukieB's profile
LukieB
966 posts in 2328 days
#2 posted 05-29-2013 01:03 PM
You should just be able to click on the “img” button
Click on the “choose file” button, select you image and then click on the “insert this image” button.
Hope that helps, sounds like you’ve got a 1940s to 1960s version of a Stanley #4, some pictures would definitely help narrow it down further.
-- Lucas, "Someday woodworks will be my real job, until then, there's this http://www.melbrownfarmsupply.com"
View Don W's profile
Don W
18715 posts in 2565 days
#3 posted 05-29-2013 05:55 PM
frog has 409 number
I think its probably a Sargent 409.
http://timetestedtools.wordpress.com/2012/08/10/sargent-planes-by-the-numberwith-pictures/
View dowdstools's profile
dowdstools
8 posts in 1823 days
#4 posted 05-29-2013 06:02 PM
As Don W said, the 409 is a Sargent number. The 409 is the equivalent of the Stanley No. 4 in size and purpose. The lateral lever will probably have a twist or a fold on the end for thumb adjustment, as opposed to an inlet tab. Sargent made a good plane.
Lynn
jackcamino
#5 posted 05-30-2013 01:30 AM
jackcamino
#6 posted 05-30-2013 01:40 AM
Well, here the pictures. Thanks LukieB. Yeah, yesterday when researching for a moment I thought it was a Sargent and not a Stanley and I am OK with that because I believe it can be used. In any case, if with the pictures someone can help me confirming and if that is the case finding a replacement lever that as you can see in the picture says Stanley and might be misplaced here. More important, I need to find a cap screw that holds together the blade and the (chipbreaker?) I think is the name of the part that goes with the blade. I appreciate all the help.
View Tim's profile
Tim
3805 posts in 1959 days
#7 posted 05-30-2013 01:42 AM
Yeah that’s what it sounded like from the description, a frankenplane. Stanley lever cap and a Sargent frog. The 409 frog comes on many of their planes that use the same size frog. I have a Sargent 414 with a 409 frog and a Sargent made hardware store plane with a broken 409 frog. I’m not one of the people that’s good enough to tell from those pictures what the other parts are from. Luckily others here are. I’m guessing most of the rest are Sargent and maybe just the lever cap has been replaced.
Don W
#8 posted 05-30-2013 02:34 AM
I agree with Tim. If its the original iron it will have a Sargent logo stamped on it. The base looks Sargent as well. A sargent cap should be fairly easy to find and you can use the Stanley cap while your looking.
Either way it will make an excellent user.
jackcamino
#9 posted 05-30-2013 03:19 AM
I will find the logo tomorrow when I clean it, now is under evaporust. In the meantime I will use it with the stanley lever but, I still need a cap screw (if that is the name of the part is missing from the picture). Lets see if I can post a picture of the part I need and hopefully here I can find someone that can send me one.
View Tim's profile
Tim
#10 posted 05-30-2013 10:38 AM
I don’t really know where to get Sargent parts besides checking eBay. I bet you’ll find some sellers there. But if your plane was advertised as complete contact the seller as they should make good on the listing if it was missing a part. Of course if the listing said as is or they didn’t know then you can’t count on it but you could still try.
Don W
#11 posted 06-03-2013 09:35 PM
View Bill White's profile
Bill White
4929 posts in 3958 days
#12 posted 06-03-2013 09:49 PM
Just be aware that Stanley used some pretty wierd thread sizes.
Bill
-- bill@magraphics.us
View HorizontalMike's profile
HorizontalMike
7757 posts in 2912 days
#13 posted 06-03-2013 10:29 PM
Jack,
The unfortunate part about these old planes is that individual parts are few and far between. And as far as ‘cap screws’, they are hard to find and one Sargent cap screw may NOT fit another. These are all one off. I only have Sargents and do not know if the Sanley cap screw “might” fit or not. That said, the only cap screws currently on eBay are Stanley. Good luck, and keep us posted.
Sometimes you just have to buy a junk plane to part out.
Don W
#14 posted 06-04-2013 12:03 AM
I’m pretty sure the newer Sargents were the same as Stanley, but of course as stated some were different. PLUS have we actually verified its a sargent cap and iron? Particularly the cap?
jackcamino
#15 posted 06-04-2013 03:13 PM
Lever cap, iron cap and iron are Stanley. The rest is Sargent. I am still missing the Stanley cap screw. Now, the question is this Frankenplane came this way from either of the factories Stanley or Sargent or it is more that a previous owner fixed it this way?
