Looking for an insert plate for a Ryobi plunge router.
Forum topic by bhacksaw posted 05-29-2013 08:11 AM 8284 views 0 times favorited 10 replies Add to Favorites Watch
View bhacksaw's profile
bhacksaw
163 posts in 1818 days
05-29-2013 08:11 AM
I’m looking to make a cheapo router table (basically, just plywood with an insert plate recess routed into it) and am looking for an insert plate that will fit a Ryobi 2 HP Plunge Router RE180-1PL. Also, is there any benefit to using phenolic rather than aluminum? I’ve heard that phenolic plates are often not level.
My first post! Thanks for the help!
10 replies so far
View toolie's profile
toolie
2121 posts in 2622 days
#1 posted 05-30-2013 02:21 AM
if a very inexpensive router table is your objective, skip the insert plate entirely. remove the base form the router and use it as a template for locating mounting holes for the router on the bottom of a piece of flat plywood. drill a hole for the bit, reattach the base to the router, mount the router to the underside of the plywood and off you go.
Rick Dennington
5851 posts in 3188 days
#2 posted 05-30-2013 03:28 AM
Now that’s cheap…...not real practical for a lot of applications, but definitely cheap…...!!!
bhacksaw
#3 posted 05-30-2013 05:07 PM
Hmm… I guess all i was looking for with the insert plate was to make sure the surface remained flat. But, for the coast of the plate, I can just replace the plywood MANY times over if it warps. I’ll give that a shot.
I’m thinking I should laminate 2 plywood boards on top of each other to fend off warping. Should I laminate them cross-grained? Does that even matter with plywood?
View oldnovice's profile
oldnovice
6833 posts in 3361 days
#4 posted 05-30-2013 07:00 PM
I suugest skipping the plywood and use 1” thick MDF (you will lose 1” of routing depth unless you relieve the underside). You can make a good insert plate out of 1/2” Baltic birch or almost any plastic; i.e. Plexiglas, poly carbonate, ABS, my favorite UHMW as it’s slippery and machines easily. Check for plate deflection regardless of the weight of the router!
If you want you can add covering to it for a more durable finish.
View pintodeluxe's profile
pintodeluxe
5653 posts in 2807 days
#5 posted 05-30-2013 07:26 PM
Plunge routers are not the best for a router table, because you have to fight the plunge spring to make adjustments.
You might try Rockler for a plate. Bench Dog makes good aluminum plates that are pre-drilled for common routers. Worst case, you might have to drill new mounting holes.
oldnovice
#6 posted 05-30-2013 11:03 PM
pintodeluxe some plunge models can be modified to work in a RT and, in fact, the are kits available to make adjustments that use a screw similar to a route lift. The only problem with these types of lifts is that they cannot raise the router above the plate since they use the router mechanics as opposed to add-on lift hardware.
Rockler Raizer is one of these!
And at the other cost end is my favorite!
404 - Not Found
2544 posts in 2963 days
#7 posted 05-30-2013 11:13 PM
When I win the lottery, I will have a workshop equipped with all manner of fancy-pants machinery and accessories, until then, I will make do with simpler things you can get off ebay to do tasks such as raise and lower a plunge router in a router table.
oldnovice
#8 posted 05-31-2013 12:40 AM
renners, that is what I was looking for in my previous, #6, post. All I could find was the Router Raizer! That is definitely the low cost and good solution. Again, this will need offset wrenches as the router cannot be raised above the table to change bits.
I don’t have a router lift but if I did it would be the one I pictured in #6 post!
View cutworm's profile
cutworm
1075 posts in 2787 days
#9 posted 05-31-2013 12:49 AM
I bought a blank plate and just drilled the mounting holes myself. Worked well. 30 bucks for the plate.
http://www.routertabledepot.com/deacin.html
-- Steve - "Never Give Up"
bhacksaw
#10 posted 07-23-2014 09:21 PM
A belated Thank you, friends. I ended up just drilling some holes through a laminated shelf I got from HD. Used it as a clamp-on router table. It worked fine until I got some ants in my pants, then I just built my own table:
