Can this texture be made using a hand held router?
Forum topic by tool_junkie posted 05-29-2013 01:18 AM 1818 views 0 times favorited 9 replies Add to Favorites Watch
View tool_junkie's profile
tool_junkie
321 posts in 2492 days
05-29-2013 01:18 AM
So I came across this pattern and was wondering if it can be made using a hand held router. I know it will be a piece of cake on a CNC machine but I don’t have one. Thought I would ask…
Thanks!
9 replies so far
View RussellAP's profile
RussellAP
3103 posts in 2250 days
#1 posted 05-29-2013 01:36 AM
You may need some tequila first.
View yrob's profile
yrob
340 posts in 3616 days
#2 posted 05-29-2013 03:31 AM
i would do that by hand with carving gouges. it will give you
the slight irregularities that the pattern has.
-- Yves
View Bluepine38's profile
Bluepine38
3379 posts in 3049 days
#3 posted 05-29-2013 02:09 PM
You could make it with a hand held router, a very steady hand and a few custom made router bits. But
some LJs such as Benji have the skill and ability to do it with hand tools. I am capable of just looking and
admiring their ability.
View PurpLev's profile
PurpLev
8534 posts in 3612 days
#4 posted 05-29-2013 02:14 PM
this is a perfect example of handheld router doing “straight lines” – the irregularities you would have because of the freehand work is going to give you this look. but I think that a carving gauges would be a better choice.
View Underdog's profile
Underdog
1074 posts in 1999 days
#5 posted 05-29-2013 02:28 PM
The pattern you see is created by depth variation. The pattern gets wider as more width of the bit is used.
If anyone has the skill to do that with a handheld router, I’d love to see it.
-- "woodworker with an asterisk"
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2036 days
#6 posted 05-29-2013 10:52 PM
The jig would be an undulating jig, Like to side by side sin waves, to pull the bit up and down. (as Underdog describes) Make it with layers of bendy laminated and give it a little left to right bend in a place, although your sample appears to be just straight lines, I like it to wiggle a little to be more organic. Mark alignments and flip it around each time you run to nest the “waves together”. You can get a more random effect by justifying in up and down a little each run or so, or by combining to different jigs. Use a plunge round over bit, In a palm router or larger with a modified base. (I put a 2 inch straight piece across the base with locks on the left and right, to lock over the left and right side of the “wave” jig allowing the larger router to follow the curves better and to keep the “buried” bit from walking left and right. I have done with a collar as well, but the table size sorta affects the way it follows the undulations. Palm router for smaller detail. Experiment with different plunge bits. It seems really hard to wrap the knoggin around, but can be done fairly well without a cnc. The difference between this method, and a hand carved is the valleys will follow the peaks. If you want them flat like cnc versions you have to hand carve, or hand carve the valleys.
Another version of this jig has the valleys slightly skew or opposing on the right and left sides of the jig. This has the effect of wiggling the bit left and right as it is tracking as well as up and down.
-- Who is John Galt?
tool_junkie
#7 posted 05-30-2013 04:45 AM
Thanks guys!
The more I read your posts and think about the setup, the more I realize that it is not an easy task using a hand held router. I had initially thought it to be just a little bit more complex that fluting, but I was wrong.
Thanks for all the info you guys shared on this.
View redSLED's profile
redSLED
790 posts in 1856 days
#8 posted 05-30-2013 12:31 PM
Curvy (flexible/reversible) jigs and big round nose bits?
Or sculpt out of clay, then paint on wood colours/grain, bake in oven.
redSLED
#9 posted 05-30-2013 12:33 PM
Or super high pressure sand blast the pattern into a very soft wood, then sand by hand?
