cheap water based primer?
Forum topic by noone posted 05-28-2013 06:57 PM 1035 views 0 times favorited 5 replies Add to Favorites Watch
View noone's profile
noone
583 posts in 2359 days
05-28-2013 06:57 PM
I’ve been using Zinsser BIN as a primer on bare wood, but i’m getting tired of cleaning with ammonia or denatured alcohol. I’m looking to change up to a water based primer, something that costs less that $42 gallon and sands easy and cleans up with water. Something that I can get from Home Depot or Sherwin Williams would be preferable.
Again, this is for new, bare wood projects.
Suggestions?
5 replies so far
View sgv's profile
sgv
266 posts in 1978 days
#1 posted 05-28-2013 08:38 PM
SW makes a white lacquer undercoater about $25, can be painted over also a wood and wall primer, $29, sands ok
also a bonding primer on sale $25 sighn up for a PC acct. get 10% off and coupons for $10 off of $50 spent(I sound like a add, but I answer the phone hello Sherwin Williams)
-- Tite Lines, May the wind be at your back
View RonInOhio's profile
RonInOhio
721 posts in 2950 days
#2 posted 05-28-2013 08:46 PM
Kilz Latex 2 Interior/Exterior Primer and Sealer. 16.98 a gallon at Lowes. About .70 cents a gallon cheaper
at Wal-Mart.
This stuff works well for me. Its loaded with solids. Not a watery cheap primer. Clean-up is so/so. Not too bad. Soap and water.
Not sure what you are used too for coverage. Most cases you will need 2 coats with just about any primer on bare wood I would think.
Shawn Masterson
1325 posts in 2034 days
#3 posted 05-28-2013 09:20 PM
I use the latex from the BB. I spray it through a cheap gun from HF. I do thin it with water about 25% give or take.
404 - Not Found
2544 posts in 3055 days
#4 posted 05-28-2013 10:02 PM
I must admit I like the BIN for speed of drying but clean up is a PITA and it is really expensive here – $30 litre. Acrylic primers would work and adhere well but you are looking at 2hr recoat time and grain raising / more prep to prevent grain raising. What kind of things do you typically paint?
View Bill White's profile
Bill White
5011 posts in 4046 days
#5 posted 05-28-2013 10:43 PM
Cheap and Primer do not do well together.
Whassa matter with good old dewaxed shellac? Washes out with a bit of dish soap and amonia.
Bill
-- bill@magraphics.us
