Stubborn Blade Screws
Forum topic by thelt posted 05-28-2013 09:27 AM 794 views 1 time favorited 6 replies Add to Favorites Watch
View thelt's profile
thelt
665 posts in 3404 days
05-28-2013 09:27 AM
Can anybody help me with some stubborn screws that hold the blade of my Ryobi Planer? I’ve tried soaking with WD-40, Liquid Wrench and a few other lubricants. I still can’t get half of ‘em out. I want to sharpen the blades but can’t get them out of the d%$# planer.
-- When asked what I did to make life worthwhile in my lifetime....I can respond with a great deal of pride and satisfaction, "I served a career in the United States Navy."
View knotscott's profile
knotscott
8056 posts in 3400 days
#1 posted 05-28-2013 09:34 AM
If you’ve got an impact driver, find the appropriate bit and try that. Works like a charm for me.
View booklikeabook's profile
booklikeabook
2 posts in 1985 days
#2 posted 05-28-2013 11:24 AM
Penetrating Oil
Machinist’s Workshop magazine actually tested penetrants for break out torque on rusted nuts.
Significant results!
They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a “scientifically rusted” environment.
Penetrating oil ….. Average load
None …................... 516 pounds
WD-40 …................. 238 pounds
PB Blaster …........... 214 pounds
Liquid Wrench ….... 127 pounds
Kano Kroil …............ 106 pounds
ATF-Acetone mix…....53 pounds
The ATF-Acetone mix was a “home brew” mix of 50 – 50 automatic transmission fluid and acetone.
Note the “home brew” was better than any commercial product in this one particular test.
Our local machinist group mixed up a batch and we all now use it with equally good results.
Note also that “Liquid Wrench” is about as good as “Kroil” for about 20% of the price.
View lumberjoe's profile
lumberjoe
2899 posts in 2273 days
#3 posted 05-28-2013 01:26 PM
I’ll have to try that out! I use straight diesel (or kerosene) which works really well but is a little dangerous
View jack1's profile
jack1
2107 posts in 4052 days
#4 posted 05-28-2013 06:00 PM
An old mechanic taught me to first “tighten” the screw a little bit then try backing them out. This action will break a bond that might have formed. It works more times than you would imagine with no extra clean-up of oils etc.
jack
View bold1's profile
bold1
293 posts in 1872 days
#5 posted 05-28-2013 08:49 PM
The best penetrating oil I have ever found is the old Army Rifle Bore cleaner for corrosive primers that came in the green Pouch cans. If that doesn’t eat through I know of nothing that will. Be careful with it. The acid in it will eat the blueing off a rifle if not wiped off. It also lifts paint and will discolor some metal.
View gfadvm's profile
gfadvm
14940 posts in 2714 days
#6 posted 05-29-2013 01:46 AM
Make ABSOLUTELY certain that you have the right bit/driver (most of those tools require metric). Then use an impact driver. If no impact driver is available, smack the bit with a ball peen hammer, and then remove it.
I learned all these tips at the Ridgid service center when I couldn’t get the screws out of my planer. The ball peen trick worked much better than I would have thought.
Then when you put the screws back in, DON”T use the impact driver.
