BLO and Shellac finish
Forum topic by Straightbowed posted 05-27-2013 05:36 PM 4816 views 1 time favorited 20 replies Add to Favorites Watch
View Straightbowed's profile
Straightbowed
717 posts in 2292 days
05-27-2013 05:36 PM
Im finishing a cherry coffee table it is old dark cherry lumber that I found in a barn, but anyway I read an article in FW that you can use BLO then wipe off then go with 3 pound cut of shellac right on top as soon as you wipe off the blo I hate finishing but this is for my daughter and I was wondering if this will work? I guess I can do a test pc as usual but really need a quick tip or just go with shellac and be done with it
-- Stevo, work in tha city woodshop in the country
20 replies so far
View Sirgreggins's profile
Sirgreggins
299 posts in 2229 days
#1 posted 05-27-2013 05:41 PM
If fw says its ok it probably is. I always wait until the BLO is dry before applying shellac but that’s only b/c that’s what I was told to do
View Loren's profile
10373 posts in 3642 days
#2 posted 05-27-2013 06:04 PM
It should work ok. The shellac will stick and the oil
will cure underneath.
4981 posts in 2487 days
#3 posted 05-27-2013 06:06 PM
Actually, Jeff Jewit also uses that finish schedule, he refers to it as “quick and dirty french polish”. In his explanation of it, he suggests you make it a very thin coat of BLO (cut with MS, wipe off quickly).
Straightbowed
#4 posted 05-27-2013 06:07 PM
it says to apply the blo then wipe down good then go with shellac FWW 2012 fall issue I will try a test pc and if I don’t like it I will just go with shellac tinted with amber dye. thanks for the help just need to get off my rear and get goin
View bondogaposis's profile
bondogaposis
4717 posts in 2345 days
#5 posted 05-27-2013 06:29 PM
I use a mixture of shellac and BLO as a friction polish on my wood turnings and it works fine.
-- Bondo Gaposis
Straightbowed
#6 posted 05-27-2013 06:40 PM
thanks guys, just really needed to be reassured goin for it, here I go>>>>>>>>>>
View Jorge G.'s profile
Jorge G.
1537 posts in 2469 days
#7 posted 05-27-2013 11:13 PM
The only good thing about the french polish book I bought and reviewed was the part about using plaster of Paris as grain filler and then using BLO to wipe on top as the shellac won’t change the color alone. So I guess using BLO before shellac is not a problem.
-- To surrender a dream leaves life as it is — and not as it could be.
View Tkf's profile
Tkf
38 posts in 1921 days
#8 posted 05-27-2013 11:27 PM
Yup. I’ve tried this too. It doesn’t have to be a 3 pound cut though. Any cut works. :)
View gfadvm's profile
gfadvm
14940 posts in 2684 days
#9 posted 05-28-2013 01:28 AM
I have applied shellac immediately after BLO was rubbed into the wood (several successive coats) and had no problems at all. I do my BLO a little different than others: I never “flood” the surface but just use a small wad of cloth and keep rubbing BLO on until no more absorbs into the wood. I usually cut my BLO with equal parts mineral spirits.
View Finisherman's profile
Finisherman
227 posts in 1843 days
#10 posted 05-28-2013 04:47 PM
To me. at least, it would seem safer to let the BLO cure for a few days before you apply the shellac. I’m just not comfortable with the idea of applying a finish over an uncured layer of oil. The oil cures by oxidation, and it stands to reason that, by cutting off the oxygen with a layer of shellac, you may arrest the curing process. As others have said, you might want to thin your oil with mineral spirits and apply only a thin coat. The purpose of the oil is to accentuate the wood’s figure. Then, I’d let the oil cure, at least overnight, and proceed to the shellac. As one other person said, you don’t need to use a three pound cut of shellac. You’ll probably find the shellac much easier to brush if you thin it to a one-and-a-half pound cut with denatured alcohol and apply an extra coat or two. Lastly, the idea of testing your finish on scrap is an excellent one.
bondogaposis
#11 posted 05-28-2013 06:30 PM
Shellac is cut w/ methanol, and if you remember high school chemistry methanol is CH3OH. There is oxygen in the alcohol that cures the BLO, it doesn’t need atmospheric oxygen.
-- Bondo Gaposis
Finisherman
#12 posted 05-28-2013 06:59 PM
Thanks. I didn’t know that the oxygen in the methanol would help the oil cure. I always enjoy learning something new!
View Roger's profile
Roger
20928 posts in 2798 days
#13 posted 06-02-2013 12:07 PM
Thnx for the post. I’m learnin more n more from all ya’ll
View shampeon's profile
shampeon
1775 posts in 2177 days
#14 posted 06-03-2013 03:33 AM
Tried a BLO/mineral spirits/shellac mixture (equal parts, more or less) today on a tool stand I’m building, and so far so good. No problems mixing it up, and it worked just like Danish oil, more or less. Gave the doug fir, pine, poplar a nice look.
I also made a mixture of Watco Danish oil and tinted shellac a few days ago, and again had no problems. Had the sheen and glow of an oil finish with better drying time.
View JAG07's profile
JAG07
9 posts in 1352 days
#15 posted 09-06-2014 08:33 PM
This is perfect. I was looking for something exactly covering this topic about finishing cherry. I’m going to try the shellac.
I’m curious if any of you have used wax over BLO. I tried it on a piece of cherry and I’m not too enthused with the results. It does not seem smooth no matter the amount of buffing. I’m buffing by hand so I’m considering getting a buffing brush or pad for my drill.
Did I mention I’m totally new and almost completely ignorant of most things? I’m looking forward to delving into this forum and learning as much as possible…before I ruin perfectly good pieces of wood.
-- Learning/ruining wood with a few happy mistakes. KCCO
