Broken Bandsaw
Forum topic by lew posted 05-27-2013 02:46 AM 1263 views 0 times favorited 7 replies Add to Favorites Watch
View lew's profile
lew
12498 posts in 3992 days
05-27-2013 02:46 AM
Anyone know where I might get a replacement part for a 14” Bridgewood bandsaw? I broke the “support” that holds the upper guide blocks and thrust bearing. I could replace it with a Carter product but they cost about half as much as the bandsaw did originally.
Thanks
Lew
7 replies so far
View Dan'um Style's profile
Dan'um Style
14179 posts in 4220 days
#1 posted 05-27-2013 02:59 AM
try grizzley
View Deycart's profile
Deycart
444 posts in 2495 days
#2 posted 05-27-2013 03:08 AM
I would try some JB weld first. If you mess it up your only out 5 bucks or so.
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#3 posted 05-27-2013 03:20 AM
That looks almost identical to the Delta upper blade guide without the ‘micro adjust’ thumbscrews (upper right in the photo below). I bet one from a Delta or one of it’s clones would work if you can’t find a direct Bridgewood replacement.
Note: The one shown above is for an older (1950) Delta BS with the hex guide bar.. newer ones use a round one like your Bridgewood.
View lew's profile
lew
#4 posted 05-30-2013 12:55 AM
Well Grizzly wouldn’t measure the part I thought might fit. Didn’t hear back for C.H. Wilke. So, I took Deycart’s advice and got some JB Weld and bent a U-shaped piece of metal to fit around the broken piece. It ain’t pretty but it’s holding together.
Thanks for the ideas and suggestions
Deycart
#5 posted 05-30-2013 01:00 AM
JB Weld is my friend. Check this out
http://lumberjocks.com/Deycart/blog/34986
View lew's profile
lew
#6 posted 05-30-2013 01:26 AM
Cool repair job on that plane!
View Roger's profile
Roger
20965 posts in 3041 days
#7 posted 06-02-2013 09:38 AM
Sheesh. Good luck. I don’t have a clue
