Cutting copper with my bandsaw
Forum topic by unisaw posted 05-27-2013 12:20 AM 1418 views 0 times favorited 5 replies Add to Favorites Watch
View unisaw's profile
unisaw
92 posts in 4373 days
05-27-2013 12:20 AM
Topic tags/keywords: brass bandsaw blade cut question
I recently bought the Hock spokeshave kit and the instructions call for assembling the tool with the brass plate and then shaping it on the bandsaw which means cutting through the brass. See this video at the 6:25 point:
http://www.hocktools.com/videos.htm#KSPVideo
I have a Rikon 16” with the blade that came with the saw and two Highland blades – the 1/2” wood slicer and a 1/2” 3 TPI blade. Can I use any of these to cut the brass?
5 replies so far
View bondogaposis's profile
bondogaposis
5153 posts in 2591 days
#1 posted 05-27-2013 12:39 AM
I wouldn’t, you need a finer tooth blade, something like 10 tpi.
-- Bondo Gaposis
View Loren's profile
10477 posts in 3887 days
#2 posted 05-27-2013 12:44 AM
Use a finer blade and expect to wreck it. Wood cutting
bandsaws run too fast to cut metal.
I would use something else.
View Dallas's profile
Dallas
3599 posts in 2727 days
#3 posted 05-27-2013 12:59 AM
Got a jigsaw?
View gfadvm's profile
gfadvm
14940 posts in 2930 days
#4 posted 05-27-2013 01:24 AM
Most brass is pretty soft and I think you’ll get along fine with your bandsaw using a 10 TPI or finer blade. I have sawed many miles of brass with jeweler’s saws and it is not hard on blades at all so you could use a fret saw or jewelers saw instead of your BS.
View ScaleShipWright's profile
ScaleShipWright
253 posts in 2125 days
#5 posted 05-27-2013 08:28 PM
I second gfadvm, take your time and cut it by hand, I also suggest a little wax on the blade for a smoother action.
-- God exists... But relax, He's not you!
