what type of screws and the lenght
« back to Woodturning forum
Forum topic by coachmancuso posted 05-27-2013 12:10 AM 1232 views 0 times favorited 8 replies Add to Favorites Watch
View coachmancuso's profile
coachmancuso
259 posts in 1893 days
05-27-2013 12:10 AM
I am going to turn a bowl tomorrow using a faceplate . The block is 6 inches square and 4 inches deep. I need to know what type of screws to use and the length of them? Thanks
-- Coach Mancuso
8 replies so far
View Kreegan's profile
Kreegan
1452 posts in 2108 days
#1 posted 05-27-2013 01:22 AM
#6 sheet metal inch to inch and a quarter.
View JollyGreen67's profile
JollyGreen67
1658 posts in 2725 days
#2 posted 05-27-2013 01:34 AM
What Rich says.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
coachmancuso
#3 posted 05-27-2013 01:36 AM
Thanks Rich
-- Coach Mancuso
Kreegan
#4 posted 05-27-2013 01:38 AM
I highly recommend putting them in by hand instead of using a drill or impact driver. If you do use a machine, be very very careful not to strip the screws out in the wood.
View TheDane's profile
TheDane
5399 posts in 3625 days
#5 posted 05-27-2013 01:49 AM
If the face plate has counter-sunk holes, I use #8×1 1/4” steel wood screws. If the face plate holes are not counter-sunk, I use #8 sheet metal screws. Pre-drill holes and tighten by hand. Whatever you do, don’t use drywall screws … they are too brittle and can snap when you get a catch or dig-in.
View rustfever's profile
rustfever
751 posts in 3272 days
#6 posted 05-27-2013 02:57 AM
Use screws that will penetrate the wood not less than 5/8 inch, but I prefer not less than 3/4”. I prefer flat-head wood screws, but will also use pan head sheet metal screws. Always pre-drill every screw BUT NEVER USE DRYWALL SCREWS.
-- Rustfever, Central California
coachmancuso
#7 posted 05-27-2013 03:00 AM
Thanks everyone
-- Coach Mancuso
View Bluepine38's profile
Bluepine38
3379 posts in 3047 days
#8 posted 05-27-2013 04:10 PM
I agree with most of the above, but I use steel screws to form the screw holes, then replace them with
brass or bronze screws, then when I goof, I do not ruin a lathe chisel. For blanks that small I use a
sacrificial wood plate, and glue the block to it with a piece of newspaper between the wood surfaces,
this allows you to separate the wood easily and it is still strong enough to turn with is you are steady and
smooth with your chisels. Just my opinion.
