time between shellac and water poly finish?
Forum topic by JesseTutt posted 05-26-2013 05:33 PM 1704 views 0 times favorited 11 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2197 days
05-26-2013 05:33 PM
Topic tags/keywords: shellac finish dry time water based poly
I am trimming out a window with 1/4” oak veneer ply. I want to use shellac to get the warm brown look of an oil finish, but the top finish will be water based poly. With the temperature in the mid to high 70s what is the minimum dry time for the shellac before I can spray the poly on?
11 replies so far
5035 posts in 2579 days
#1 posted 05-26-2013 05:52 PM
If it’s good shellac (not too old), I’d say pretty quickly. I wouldn’t be afraid to apply the waterborne the same day. Shellac is pretty much dry once the solvent has evaporated….that will happen even more quickly in warm temps. You will want that to be dewaxed shellac….
JesseTutt
#2 posted 05-26-2013 06:05 PM
Yes I am using dewaxed shellac that I mixed yesterday from fresh alcohol and old flakes that were kept dry. Initial color test has the shellac drying without any problems.
View GuyK's profile
GuyK
356 posts in 4165 days
#3 posted 05-26-2013 06:05 PM
Jesse, Fred is right, you can apply your top coat rather quickly over the top of shellac. In my shop I use a mixture of shellac and denatured alcohol. I let it dry for about 1 hour to 1 1/2 hours, then lightly sand and top coat with a water based poly. Good luck.
-- Guy Kroll www.thelandsathillsidefarms.org
View NiteWalker's profile
NiteWalker
2737 posts in 2663 days
#4 posted 05-26-2013 06:33 PM
I’ve top coated dewaxed shellac after 45min with a waterborne with no problems.
JesseTutt
#5 posted 05-26-2013 07:05 PM
Thanks All!
Follow-up question: The back side of the ply will be glued to the (birch?) plywood that came as part of the bay window. Normally I would apply the same number of coats of the same finish to the back side. In this case do I really need to shellac the back that will be glued, or is the water based poly sufficient?
Guy: I understand you to say that you sand after the shellac with a lubricant of water based poly prior to spraying poly?
16276 posts in 4304 days
#6 posted 05-26-2013 07:36 PM
Jesse, maybe I am misunderstanding your question, but the main reason to finish both sides of something (other than cosmetic) is to prevent one side from absorbing more moisture than the other. If one surface is going to be glued directly to something else, there is no need for any finish at all.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3244 days
#7 posted 05-26-2013 07:55 PM
I’ve topcoated sealcoat shellac within 20 minutes here in Texas. Probably could have done it sooner.
-- jay, www.allaboutastro.com
View GuyK's profile
GuyK
#8 posted 05-27-2013 01:53 AM
Jesse, what I do is lightly sand the shellac then use a water based poly as the final coat.
NiteWalker
#9 posted 05-27-2013 02:01 AM
I sand the shellac with 320 before spraying the wb poly.
On the insides or non-show sides of things I do spray the shellac, but only 1 or 2 coats of wb poly. Otherwise it’s a waste.
JesseTutt
#10 posted 05-27-2013 04:01 AM
NiteWalker: why the shellac on the non-show sides? Won’t the wb poly seal the wood?
NiteWalker
#11 posted 05-27-2013 05:35 AM
I do it because the wb poly alone would raise the grain more than the shellac. So after the first coat I’d have to sand a bit more. The shellac raises it very little; a light swipe with 320 and it’s ready for poly.
But if saving time is the objective, wb poly alone works fine. On things like small cabinets or shelves it actually helps. The wb poly gives the wood no color at all, so it’s a tad brighter than with a coat of shellac first. This helps keep the interior looking bigger than it is.
But since I have the shellac in the gun and it doesn’t take a whole lot to spray a quick coat on insides/no-show sides, I do it.
