Convert handwheel lathe tailstock to crank
« back to Woodturning forum
Forum topic by John Truffa posted 05-26-2013 01:56 PM 3556 views 0 times favorited 10 replies Add to Favorites Watch
View John Truffa's profile
John Truffa
14 posts in 2704 days
05-26-2013 01:56 PM
I have an older model Craftsman 12” lathe that has a handwheel in the tail stock (wheel is in the middle of the tailstock). I just began turning peppermills and its a little difficult drilling the 1 1/16” hole with a handwheel. Is there a way I can convert the handwheel to crank that fits into the end of the tailstock?
Thanks so much!
John
10 replies so far
View jumbojack's profile
jumbojack
1673 posts in 2529 days
#1 posted 05-26-2013 02:27 PM
John back in the olden days some cars were aftermarket equipt with what we called a suicide knob. Simply put it was like a gearshift knob on a spindle attached to the steering wheel. This was in the days before powersteering. You could generate tremendous torque with these things. I think with a little ingenuity you could come up with something like that for your lathe.
jumbojack
#2 posted 05-26-2013 02:29 PM
or something as simple as what I came up with for my bandsaw;
http://lumberjocks.com/jumbojack/blog/33089
I have since cut off the upper portion of the brace. This thing, ugly as it is works flawlessly. I cant believe I did not think of it before.
John Truffa
#3 posted 05-27-2013 01:39 PM
I posted the issue of converting my Craftsman lathe hand wheel tailstock to one with a crank on the end of the tailstock. I’ve been looking for a whole tailstock replacement but to no avail. The bed is 2 1/4” tube that the tailstock fits onto. If anyone knows where to get one or has one it would be greatly appreciated.
Thanks again,
John
View Kenbu's profile
Kenbu
31 posts in 1785 days
#4 posted 05-27-2013 11:26 PM
John, can you post a picture of your tailstock? Might help folks understand your situation and give better suggestions.
Ken
View REO's profile
REO
928 posts in 1979 days
#5 posted 05-28-2013 01:46 AM
if you are going to be drilling often in the future why not make a tail stock for drilling specifically. just a few pieces and a little time fabricating and you can make a lever tail stock so that you don’t have to crank it in and out just run the lever. I have one made for drilling and one for taking out the inside of a bowl. her is a hot of the bowl cutting one.
http://www.youtube.com/watch?feature=player_detailpage&v=Z1sf00vxB3M#t=146s
John Truffa
#6 posted 05-28-2013 11:29 AM
Here’s an image of the existing tailstock. I’m not sure if I can remove the hand wheel and thread the inside of the tailstock to fit a hand crank at the end therefor the reasoning for replacing the entire tailstock.
View shampeon's profile
shampeon
1775 posts in 2088 days
#7 posted 05-28-2013 04:25 PM
That is a pretty slick modification, REO. I’d love to see some pictures and an explanation of how you designed it.
View Rick_M's profile
Rick_M
11103 posts in 2285 days
#8 posted 05-29-2013 08:23 PM
John I have a different Craftsman lathe but the same issue, drilling with that little tailstock wheel sucks b@lls. My plan was to make a wood crank to replace the handwheel.
Not sure what yours looks like but here’s my tailstock wheel.
I planned on making something like this from a good hard wood.
But after seeing JumboJack’s bandsaw mod, I’m might give that a try.
-- http://thewoodknack.blogspot.com/
View REO's profile
REO
#9 posted 05-29-2013 09:17 PM
I’ll get up a drawing for it and post it. it would help to get some pics from the OP of their tailstock and some dimensions of the bed rails and center height.
View REO's profile
REO
#10 posted 05-30-2013 03:30 AM
Here are a couple drawings of the mechanism one with the quill retracted and the other with it extended. dimentions can be fudged for the application. I use shoulder bolts in drill reamed holes for the conection points. this also helps to keep the quill from turning without a key.
