8 hole adhesive sanding discs
Forum topic by dpwalker posted 05-26-2013 02:18 AM 1782 views 0 times favorited 10 replies Add to Favorites Watch
View dpwalker's profile
dpwalker
273 posts in 2829 days
05-26-2013 02:18 AM
I wasn’t sure where to post this question so please bear with me. Does anyone know a good source for 5” 8 hole adhesive sanding discs? Locally I can only find hook & loop 8 hole or adhesive without holes. Maybe they are phasing out the adhesive with holes? I found a few places online but the selection is limited. Any help is appreciated.
-- You have not really lived until you do something for someone who can never repay you.
10 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2036 days
#1 posted 05-26-2013 02:48 AM
Klingspore sells 7 different grits of 5×8 psa:
http://www.woodworkingshop.com/category.aspx?id=21&f1=5+++X+8+HOLE&f2=ADHESIVE
About $13 for a pack of 50.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View JoeinGa's profile
JoeinGa
7736 posts in 2005 days
#2 posted 05-26-2013 12:21 PM
Depending on what brand ROS you have, you might be able to save a few bucks in the long run by changing the pad to a hook-n-loop style.
View Tennessee's profile
Tennessee
2873 posts in 2512 days
#3 posted 05-26-2013 12:36 PM
Due to all the problems years ago with the pressure sensitive adhesive getting hot while sanding and falling off, most all manufacturers have tone to hook and loop. You can change your PSA sander over to hook and loop rather easily, as there are many changeover pad products out there. I did an early Porter Cable, and it is still in my collection today.
Just Joe is right, Klingspor has a bunch of PSA discs, but to be honest, I would be thinking of changing over if you intend to use the tool for years to come.
View CharlesNeil's profile (online now)
CharlesNeil
2399 posts in 3869 days
#4 posted 05-26-2013 01:26 PM
www.industrialabrasives.com
We use their white line “Rhyno” disc exclusively , best Sandpaper out there in my opinion .
View RussellAP's profile
RussellAP
3104 posts in 2285 days
#5 posted 05-26-2013 01:27 PM
Try Abrinet, you don’t have to worry about holes with it.
View Bill White's profile
Bill White
4930 posts in 3958 days
#6 posted 05-26-2013 02:34 PM
+1 Charles’ for Rhyno. My guys pitched a fit when I bought Mirka.
Bill
-- bill@magraphics.us
dpwalker
#7 posted 05-27-2013 12:19 AM
Thanks for the helpful relies. As I said adhesive paper is getting rare around here. I will eventually change the pad on my sander but for now I have a few good leads. Thanks again.
View ,'s profile
2387 posts in 3545 days
#8 posted 05-27-2013 01:34 AM
We run Dynabrade with PSA pads. I dont agree that the PSA paper is somehow less quality than hook n loop. In fact PSA paper cost much less for equal or greater quality paper. For 34.00 I can get 100 qty of very high quality PSA disc.
So switching your pad to hook and loop would actually be doing yourself a disservice, I would want to always look to better my equipment. Changing your pads to hook n loop would be like me deciding to go from Dynabrade DA sanders to a 29.00 Black and Decker ROS :)
Of course online sources that I know of are www.industrialabrasives.com and I also use www.supergrit.com. I actually get my paper locally at Louis and Company.
View MrRon's profile
MrRon
4769 posts in 3241 days
#9 posted 05-27-2013 04:00 PM
If PSA paper is failing, it’s either poor quality discs or improper use. If you apply too much agressive force, you will overheat the adhesive. ROS’s don’t require a lot of downward pressure. The weight of the sander is enough for the disc to do it’s job. This applies to other types of sanders also. H&L discs are convenient if you only have one sander and need to change grits. PSA is great if you have more than one sander with a dedicated grit on each.
View beech's profile
beech
7 posts in 2031 days
#10 posted 11-09-2013 08:16 PM
Check out AA Abrasives – www.aaabrasives.com – I love their gold a/o sanding discs
They come in rolls or stacked in a box. Ship out same day – I never have to wait long for my delivery.
