Drill press runout
Forum topic by ZiggyZ posted 05-25-2013 02:51 AM 1295 views 0 times favorited 8 replies Add to Favorites Watch
View ZiggyZ's profile
ZiggyZ
65 posts in 2254 days
05-25-2013 02:51 AM
Hi
I scored a Delta 16 1/2” model 17-900 drill press in like new condition today off craigslist for $75.00. I put my dial indicator on it and got runout of about .004 to .005. Is this acceptable for a press? I have my table saw within .001 and thought this might be a bit much?
Thanks for any input.
8 replies so far
View mjrausch's profile
mjrausch
20 posts in 1724 days
#1 posted 05-25-2013 03:04 AM
where did you take the reading? did you put it on the shaft, drill chuck, or did you put a drill in and idicate that?
did you also put the indicator in the chuck and indicat ethe table. depending on where you took the reading, this is not to bad.
-- mjrausch
ZiggyZ
#2 posted 05-25-2013 03:08 AM
I took two measurements, one each from the chuck and one from the shank of a Forstner bit just below the jaws of the chuck. They were both at about .004.
View REO's profile
REO
927 posts in 1943 days
#3 posted 05-25-2013 03:41 AM
for drilling holes you should be just fine. if you realy want to get wild take a reading off the forstner shank just above the flutes. mark the high reading. losen the chuck and give it a 90 degree turn and see if the wobble tracks.combined with your other readings this will also tell you if the chuck is out of paralell or off center.
View Dusty56's profile
Dusty56
11814 posts in 3557 days
#4 posted 05-25-2013 06:22 AM
Did you run the shaft (quill) all the way down and check for side to side play there as well ?
View NiteWalker's profile
NiteWalker
2736 posts in 2446 days
#5 posted 05-25-2013 05:06 PM
That reading is fine.
I never even checked runout on my drill press. It drills holes straight and the correct size. That’s all the confirmation I need.
View Mainiac Matt 's profile
Mainiac Matt
7552 posts in 2198 days
#6 posted 05-25-2013 06:14 PM
I keep a little stub of TPG shaft for making these type of runout measurements. Your Forstner bit might be the source of some of that.
Even so, I think it’s acceptable.
-- Pine is fine, but Oak's no joke!
Mainiac Matt
#7 posted 05-25-2013 06:16 PM
If you have the taper key, you could try popping the taper open, cleaning it up and reseating it.
4820 posts in 2363 days
#8 posted 05-25-2013 06:32 PM
I’d say you lucked out. Mine (bought new) had runout of about .015”, and I only recently fixed it (new chuck). I now have .003” and am quite happy with for woodworking.
