Why would I ever need a thin rip jig?
Forum topic by Cole Tallerman posted 05-24-2013 04:04 PM 1976 views 1 time favorited 15 replies Add to Favorites Watch
View Cole Tallerman's profile
Cole Tallerman
392 posts in 2424 days
05-24-2013 04:04 PM
I see homemade ones and just watched a video from rockler. They say that it keept them strait? I would just hold the piece against the fence and get the same results or use a feather board. They also said it improves safety and keeps your hands farther from the blade. They showed a demo without the jig where the guy did some very strange maneuver to cut his piece. Then they did it with the jig and he just cut it the proper way so it looked safer. Can someone please explain this to me?
Here is the rockler video:http://www.youtube.com/watch?v=Cpfcq-QHkgk
Edit: So after watching it again I understand the accurate repeatability aspect. But what is up with the dangerous demo?
15 replies so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3153 days
#1 posted 05-24-2013 04:15 PM
I agree, this TS has NO riving knife and/or NO featherboard/board-Buddies, etc. PLUS this guy is standing directly behind the TS, in the line of fire of potential kickbacks.
View Loren's profile
10477 posts in 3887 days
#2 posted 05-24-2013 04:21 PM
I’ve never had one. I use a bandsaw and planer usually.
Really thin stuff an be thicknessed with hand planes
and scrapers… or a drum sander if you have one.
A small drill drum an be mounted on a drill press with
an adjustable fence to sand to final thickness – fed
by hand. Such inventions predate electric motors.
View Brandon's profile
Brandon
4152 posts in 3190 days
#3 posted 05-24-2013 04:22 PM
It’s just taking a cue from standard infomercial stupidity.
-- "hold fast to that which is good"
View pintodeluxe's profile
pintodeluxe
5817 posts in 3052 days
#4 posted 05-24-2013 04:30 PM
With a thin rip jig, the small piece won’t get trapped between the blade and the fence. I don’t really see that as a safety improvement in this particular instance, but it may make a cleaner cut.
I just use the T.S. fence to cut strips. I trim off the end of the strip that tends to get blade marks.
View b2rtch's profile
b2rtch
4868 posts in 3287 days
#5 posted 05-24-2013 04:43 PM
I also fail to see any advantage to this jig
-- Bert
View Farrout's profile
Farrout
187 posts in 3393 days
#6 posted 05-24-2013 04:45 PM
If you don’t know, then you don’t need one.
-- If we learn from our mistakes, I should be a genius!
View MT_Stringer's profile
MT_Stringer
3183 posts in 3470 days
#7 posted 05-24-2013 04:49 PM
I made my own and use it to cut multiple strips of walnut for use in a cutting board. also, multiple strips identical for edge banding on shelves.
16281 posts in 4457 days
#8 posted 05-24-2013 05:00 PM
I agree with you about not seeing the point of their video, but I do use a homemade thin rip jig quite a bit.
As far as I’m concerned, the point of a thin rip jig is easy repeatability when cutting multiple strips of the same thickness.
Let’s say you want a bunch of strips 1/8” thick. You don’t want to try to set your fence 1/8” away from the blade for obvious safety reasons, so you are going to cut your strip by leaving 1/8” of material on the outside of the blade, right? That means you are going to have to move the fence exactly 1/8” to cut the next strip. All a thin rip jig really does is serve as a guide for moving the fence the correct distance to make the next cut.
View poopiekat's profile
poopiekat
4405 posts in 3973 days
#9 posted 05-24-2013 05:01 PM
Hmmm, clamp a scrap board to the left of the blade….or buy some goofy plastic doodad.
Uhh, Charlie: that’s 1/8th inch PLUS the width of your kerf!
#10 posted 05-24-2013 05:07 PM
Yeah, poops… thanks for the correction.
poopiekat
#11 posted 05-24-2013 05:11 PM
@Charlie: I just didn’t want to see you slicing up a perfectly good board into pure sawdust…. 1/8” inch at a time…and wondering where your strips are.
#12 posted 05-24-2013 05:47 PM
Don’t worry. I’d have figured it out….. after five or six tries.
View Kreegan's profile
Kreegan
1452 posts in 2385 days
#13 posted 05-24-2013 06:33 PM
Bob Simmons uses the Rockler thin rip jig to resaw veneer. I haven’t had a chance to try this method out yet, but it looks very solid.
http://theapprenticeandthejourneyman.com/bandsaw-resawing/
View shampeon's profile
shampeon
1895 posts in 2422 days
#14 posted 05-24-2013 06:36 PM
I made my own from scrap and a couple old thrust bearings. The point is to make repeatable cuts of a given thickness, and it’s easier to do so with a jig than a clamp and a scrap board. I’ve used it to cut veneer and some wooden binding for a guitar on a bandsaw. I haven’t tried it with my table saw, as that seems more prone to kickback.
View MrRon's profile
MrRon
5270 posts in 3482 days
#15 posted 05-31-2013 08:35 PM
The purpose of any thin strip rip guide is to rip strips very thin and with repeated thickness. The one sold by Rockler works, but the drawback is having to readjust the fence after each rip. I don’t know of any jig sold that can rip without readjusting anything after each rip. I have made jigs that can make repeatedly thin rips with no readjustment necessary. They are single purpose jigs made to accomodate stock specifically milled to fit the jig. In my model making, I frequently need strips as thin as 1/32” thick. I make a jig that fits my 10” cabinet saw and I can safely rip away.
