Zero clearance insert for 45 degree tilted blade
Forum topic by Farrout posted 05-24-2013 03:12 PM 1433 views 0 times favorited 11 replies Add to Favorites Watch
View Farrout's profile
185 posts in 3086 days
05-24-2013 03:12 PM
I recently saw a picture of one, but I can’t figure out how to make one.
Any ideas?
-- If we learn from our mistakes, I should be a genius!
11 replies so far
View verdesardog's profile
155 posts in 2543 days
#1 posted 05-24-2013 03:23 PM
make a blank insert, set it in place with the blade all the way down, turn on the saw, slowly raise the blade while it is running. not rocket science…....
-- .. heyoka ..
View PurpLev's profile
8534 posts in 3580 days
#2 posted 05-24-2013 03:26 PM
make sure you check the blade for 45 before you slot the ZCI – checking it after you cut it could be ‘too-late’ if it isn’t exactly 45
View Kaleb the Swede's profile
Kaleb the Swede
1815 posts in 1901 days
#3 posted 05-24-2013 03:29 PM
I don’t think the first guy read your question correctly.
I have never tried this but I read that one guy put a blank insert in and started out with a 7 1/4 circular saw blade and then when he had the room to replace it with his 10 inch blade he did to complete the cut. Like I said I don’t know if this will work, but it is what I read someone doing before.
Maybe someone who has done it has a better way
-- Just trying to build something beautiful
#4 posted 05-24-2013 03:29 PM
Duh, I forgot the whole blade carriage tilts. Oh well, no stupid questions, right?
13598 posts in 3273 days
#5 posted 05-24-2013 03:33 PM
make sure to hold the insert down good
with the fence and a small wedge
or a board clamped down on it
where the blade won’t cut it too
the angle of the cut
will want to raise the insert
and it can bind
and maybe kick back
View Ripthorn's profile
1454 posts in 2917 days
#6 posted 05-24-2013 03:40 PM
One thing to keep in mind is that the carriage raises at 90 while the blade is at 45. This means your blade will cut the blank insert at the right most (assuming right tilting saw) point and slowly work it’s way left. This means that it will only be zero clearance on the left side, and only for the highest blade height you raise it to. There will still be a gap left from the raised cutting on the right. If you want it truly zero clearance, you have to cut it some other way and you would need a different insert for each blade height.
View Toolz's profile
1004 posts in 3674 days
#7 posted 05-24-2013 04:06 PM
I just made a single runner sled and made a 45 degree cut. Use it all the time when making boxes.
-- Larry "Work like a Captain but Play like a Pirate!"
View toolie's profile
2116 posts in 2560 days
#8 posted 05-24-2013 06:37 PM
ZCIs for tilted blades are easy to make and work s well as regular ZCIs. particularly good when raising panels on the TS.
-- there's a solution to every just have to be willing to find it.
View stefang's profile
15874 posts in 3266 days
#9 posted 05-24-2013 07:18 PM
You could just make your insert out of two halves edge glued after making the 45 deg. slot.
View muleskinner's profile
896 posts in 2368 days
#10 posted 05-24-2013 07:23 PM
Ripthorn, I think on most saws (and I know at least on mine) once you tilt your blade, raising it is on a plane defined by the saw blade. Or to use your term, the carriage is raised at the angle you’ve set the blade.
-- Visualize whirled peas
View LoydMoore's profile
105 posts in 1888 days
#11 posted 05-24-2013 08:25 PM
OK. I just went to YouTube and typed in “zero clearance insert”. I counted at least 15 videos before I quit looking.
-- Loyd, San Angelo, TX
