Hand saw for veneer cutting
« back to Hand Tools forum
Forum topic by BertFlores58 posted 05-24-2013 01:40 AM 6855 views 1 time favorited 16 replies Add to Favorites Watch
View BertFlores58's profile
1694 posts in 2852 days
05-24-2013 01:40 AM
Topic tags/keywords: question resource jig
After researching on the internet ways of making veneers, the best method is to use hand saw however there are several ripping saws.. one of them is the one called Bow Saw where the blade is in the center. What is the ideal Teeth per inch (TPI)? Is there anyone out here that can guide me on other methods of cutting veneers manually?. My plan of buying a band saw will be delayed till December because of other priorities. I need to cut a jackfruit lumber which is 12 inches in width (already at hand and seasoned dried) and cut it to veneers of 1/16 inch thick. I will use this for construction and restoration of decade old musical instruments like mandolin, violin, and banduria only if I would be successful to cut this beautiful jackfruit into 1/8 thick boards then sand later on.
I need help on this method… specially how to sharpen the saw with 15 tpi.
Thanks for the help.
-- Bert
16 replies so far
View Woodknack's profile
11286 posts in 2310 days
#1 posted 05-24-2013 03:18 AM
I’ve only watched videos of people cutting veneer with frame saws and it looks like hard, tedious, and probably frustrating work. I would go with a 5tpi panel saw, that way you have a more useful tool when you eventually get a band saw. Incidentally, I do have a bow saw, not a frame saw (blade in the middle), but I prefer a panel saw for ripping.
-- Rick M,
#2 posted 05-24-2013 03:40 AM
Thanks Ric,
I know how tedious it will be but it is alright because I need only few boards for the musical instruments. You gave me an idea using a portable circular saw but it has only limited cutting depth… Mine has only 2-3/4 inch and double it will cut only 6-1/2 not enough to penetrate a 12 in depth total.
-- Bert
View JustJoe's profile
1554 posts in 1968 days
#3 posted 05-24-2013 03:46 AM
Sharpening a rip saw is easier than sharpening a crosscut saw. There are a few videos if you search for “sharpening a rip saw”. A decent written explanation is here:
If you use a bow-saw it will have to be one where the blade can be turned at an angle, otherwise once you’ve sawn a few inches the frame of the saw will get in the way.
If you use a regular handsaw with a rip-filed tooth you can do it, but as you know it will be slow, but doable.
If you have a thin-kerf blade on your tablesaw you can make a kerf on each side of the board and then use those two kerfs as a guide for your handsaw. That will mean less wood to cut by hand, and two grooves to help guide the saw will keep you from going astray. Then just clean up with a plane or planer or sander.
Good Luck – it sounds like some interesting restoration work.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
#4 posted 05-24-2013 03:56 AM
That’s what I do, run a kerf down both sides with my tablesaw then finish with 5tpi rip saw.
-- Rick M,
View John Ormsby's profile
John Ormsby
1283 posts in 3666 days
#5 posted 05-24-2013 04:04 AM
How about asking someone at meat butcher shop to borrow their bandsaw to cut your veneers? I am sure a bandsaw will be much quicker and more accurate.
-- Oldworld, Fair Oaks, Ca
View shipwright's profile
7935 posts in 2728 days
#6 posted 05-24-2013 05:26 AM
Bert, if the wood is of real value, try to find someone nearby who has a bandsaw and knows how to resaw.
You will run the risk of wasting a lot of material in sawdust doing it by hand without experience not to mention the amount of work it will be. If there’s any way to get it to a bandsaw, that’s what I’d do.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees.
#7 posted 05-24-2013 06:48 AM
Thanks Paul. That’s what I am afraid of. The jackfruit is really a good stuff of 12 inch width that I personally watch the drying and seasoning of it. My original plan was to use it for a bass guitar but now that I have pending restoration work for musical instruments then I need to resaw it. The thickness of the plank is about 1-1/4 inch and about 5 ft in length and I knew that it will be wasted if really not done properly. I have already tried with ordinary saw but could not make a real straight line. Started with 3/8 and down to 1/4 after planing and sanding. Thanks for the warning.
-- Bert
View stefang's profile
15859 posts in 3264 days
#8 posted 05-24-2013 07:51 AM
Not impossible, but certainly not easy either Bert. It would be an interesting challenge just for fun.
View Tim's profile
3755 posts in 1891 days
#9 posted 05-24-2013 04:46 PM
As far as I can tell the frame saw was the way this was done because the tension allows a thinner blade and kerf. But that also means much more skill is required in keeping the cut straight. Google for roubo frame saw. Shannon Rogers did a few posts on his renaissance woodworker blog about them and where to get parts to make one. I think it was him that mentioned the 4” blade depth made a big difference.
If you’re going to go this way, you’ll need to practice a lot on less valuable wood. Unless you find that idea enjoyable, I think bandsaw resawing is the way you’ll want to go.
#10 posted 05-24-2013 06:34 PM
As someone who has considered a frame saw, I found this an interesting read
-- Rick M,
View George Coles's profile
George Coles
183 posts in 2375 days
#11 posted 05-25-2013 02:14 AM
Hi Bert
Suggest that you take it to the re-saw mill in Taytay. They are not too bad at this sort of thing. Then put it through thickness-er to get it to what you want. To sharpen a saw with 15 tpi, I need REALLY good glasses and a very small three corner file. (-:
-- George Coles,
#12 posted 05-25-2013 12:33 PM
Thanks to all.
The whole day of saturday was consume fo experimenting. It was fun and really fun. I sharpened my crosscut and convert it ripsaw. It was previously sharpened using a grinder and it took me 2hours filing the nearly new set of teeth. Make the kerf bigger…. tested and found good. I will just post a blog on it later after taking pictures of what i cut 8 inches width.
George, yes i will in taytay. Thanks.
Btw using my tablet at the moment. Not very keen on touch screen keyboard.
-- Bert
View Sylvain's profile
696 posts in 2429 days
#13 posted 05-26-2013 02:17 PM
Other expériences :
Bob Razaieski had a better experience than Adam Cherubini
another one
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View Armand's profile
232 posts in 2840 days
#14 posted 05-30-2013 05:51 AM
Bert, i agree with George just take it to re-sawing shop in Taytay its very near your place and it won’t take them an hour to do the job. Don’t let even the slightest inaccuracies by handtools ruin your precius wood. Sayang naman kaibigan.
-- My Master is Mankind's Greatest Carpenter.
View Bosun's profile
20 posts in 577 days
#15 posted 08-18-2016 12:21 AM
Here’s a video of a furniture maker cutting 1/8 inch(3mm) thick veneers.
-- Bosun, Tasmania,
