HELP hole in wood
« back to Woodturning forum
Forum topic by Gatorjim posted 05-22-2013 11:27 PM 1086 views 0 times favorited 7 replies Add to Favorites Watch
View Gatorjim's profile
Gatorjim
217 posts in 2113 days
05-22-2013 11:27 PM
I was turning this piece of wood to make a box and found a hole it wasn’t there on the surface of the wood. (no idea of what kind of wood)
can I use this to fill it in and continue turning?
-- My theroy in wood working will be. If I'm not enjoying doing it i won't do it.
7 replies so far
View bondogaposis's profile
bondogaposis
4611 posts in 2260 days
#1 posted 05-22-2013 11:44 PM
It looks like pine to me. That is a knot hole that healed over. Yes, you can fill w/ epoxy.
-- Bondo Gaposis
View Woodknack's profile (online now)
Woodknack
11138 posts in 2288 days
#2 posted 05-23-2013 05:09 AM
If you use epoxy, put in a few drops of black food coloring (or any other color). Another option is use CA glue and sawdust, something colorful like padauk. If you coat around the hole with sanding sealer or thinned finish, it will prevent the CA glue from wicking and leaving a stain. You can use epoxy and sawdust but it tends to look a little muddy. Either way, I like to fill the hole before doing a final sanding.
-- http://thewoodknack.blogspot.com/
View oldnovice's profile
oldnovice
6554 posts in 3276 days
#3 posted 05-23-2013 07:35 AM
Fill ‘er up and your good to go!
View FancyCloth's profile
FancyCloth
1 post in 1739 days
#4 posted 05-23-2013 07:53 AM
-- fairy tale costumes for women Sexy ladybug costumes
View rrww's profile
rrww
263 posts in 2021 days
#5 posted 05-23-2013 12:24 PM
Check the drying color of the epoxy, some of the fast set stuff dries yellowish – you many want to add color or sawdust.
View dhazelton's profile
dhazelton
2689 posts in 2205 days
#6 posted 05-23-2013 12:52 PM
What does Tom Brokaw say?
Gatorjim
#7 posted 05-23-2013 11:08 PM
Thanks guys
