Natural Finish (Newbie)
« back to Coffee Lounge forum
Forum topic by PlanesNWood posted 38 days ago 104 views 0 times favorited 3 replies Add to Favorites
View PlanesNWood's profile
PlanesNWood
5 posts in 38 days
38 days ago
Topic tags/keywords: cedar finishing maple question
Hello All,
As you may have noticed I am new here and was looking around for some information on finishes. I am currently making a cedar chest at my local college workshop. The chest has a frame made of hard maple that I cut dados in to slide panels of cedar down into. I know that I don’t want to finish the inside of the chest cause then that would defeat the purpose of using cedar. Is there a finish/sealer that I could use on the outside of the chest that would keep that natural look of the wood?
Thanks for your help,
Adam
PS: I’ll take some pics of the chest in progress and post them
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
274 posts in 125 days
37 days ago
There are a few blogs and threads to check out:
http://lumberjocks.com/jocks/Karson/blog/1326
http://lumberjocks.com/topics/4512#reply-46665
Some finished “cure” and seal the wood and even create a durable surface on the wood while others just help seal the wood porse and such and still allow the feel of the wood to come through but leave it unprotected from little dings and scratches, which the curing finishes will protect against a little bit, nothing is immune to life though.
Welcome to LJs!
-- Rich, WNY, www.nyrockingchairs.com
View trifern's profile
trifern
4796 posts in 295 days
37 days ago
Check out Steve’s forum.
View drgoodharp's profile
drgoodharp
120 posts in 655 days
37 days ago
Hi Adam:
By cedar, I’m assuming you mean aromatic Eastern Red Cedar.
Generally, you want to avoid oil finishes on cedar because the wood contains natural compounds that are known to inhibit the proper curing of drying oils, such as linseed and tung oil. Besides, oil finishes will add some color that you indicated you did not want.
If you want a clear, yet protective finish, then I recommend using a brushed on water based polycrylic varnish.
We do a lot of cedar furniture in Kentucky and this is the finish of choice.
Spray finishing is also a possibility if you have the equipment and skills.
-- Randy (P), rustic wood crafts, Morning View, Kentucky
Bookmark And Share This Page
