Where to find
Forum topic by TCCcabinetmaker posted 05-22-2013 12:18 AM 1991 views 0 times favorited 18 replies Add to Favorites Watch
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2317 days
05-22-2013 12:18 AM
Topic tags/keywords: question
Where would one find a brushable white lacquer? Most of the sources I’d normally consult appear to be dead ends
and I have a customer that wants cabinets refinished, the doors and drawers I will spray with white lacquer, but ummm I can’t spray inside their house so… I need a brushable lacquer….
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
18 replies so far
View sgv's profile
sgv
266 posts in 1854 days
#1 posted 05-22-2013 12:21 AM
Sherwin Williams White lacquer under coater comes in Gallons and fives, when dry it can be sanded, and topcoated with finish of choice.
-- Tite Lines, May the wind be at your back
TCCcabinetmaker
#2 posted 05-22-2013 12:22 AM
brushable though??? I can get sprayable from several sources, what I need is brushable lacquer.
10242 posts in 3610 days
#3 posted 05-22-2013 12:56 AM
#4 posted 05-22-2013 01:05 AM
There were loopholes in some states – spray booths are
required in the shop but nitro can be sprayed in-situ
without. Some cabinetmakers were spraying cabinets
after installation for this reason. I do not know if these
loopholes are still around.
TCCcabinetmaker
#5 posted 05-22-2013 01:07 AM
it’s more the fumes I’m worried about in the customer’s house, If I can tint a clear brushable white then I should have no problems. Problem will be finding someone who knows how to do this.
TCCcabinetmaker
#6 posted 05-22-2013 01:30 AM
Unfortunately it’s the bathroom cabinets, where the only vent would not be convienant… though there is a large plate glass window above the bath tub that does not open…. Yeah I will never get that architectural design idea… ever….
117060 posts in 3539 days
#7 posted 05-22-2013 01:39 AM
Is it possible to use some waterborne material.
View Clint Searl's profile
Clint Searl
1533 posts in 2323 days
#8 posted 05-22-2013 02:06 AM
An acceptable compromise might be to brush on a base coat of flat latex/acrylic, and top with clear waterborne poly floor finish. I did that on my library wall project, and it turned out very well.
View kdc68's profile
kdc68
2649 posts in 2239 days
#9 posted 05-22-2013 02:18 AM
I’ve used this once before….first time and only time…and it went well…
Edit….Sorry you were looking for brushable “white” lacquer….ooops
http://www.woodcraft.com/product/2004174/8791/deft-clear-wood-finish-lacquer-gloss-quart.aspx
-- Measure "at least" twice and cut once
TCCcabinetmaker
#10 posted 05-22-2013 04:15 AM
laytex won’t stick to an oil based product long term.
Clint Searl
#11 posted 05-22-2013 12:09 PM
Aaww, sure it will.
TCCcabinetmaker
#12 posted 05-22-2013 09:22 PM
lol no clint, it won’t
404 - Not Found
2544 posts in 2931 days
#13 posted 05-22-2013 11:36 PM
Try using a small short pile or foam roller. Would a clear water based acrylic gloss varnish do it?
View vipond33's profile
vipond33
1405 posts in 2460 days
#14 posted 05-23-2013 01:26 AM
Take a look here.
-- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome.
View johnmack's profile
johnmack
1 post in 1102 days
#15 posted 04-13-2015 02:34 PM
So did you find a white lacquer which is BOTH brushable and sprayable. If yes, how did it work?
