Forum topic by Lou Penta | posted 05-21-2013 10:36 PM | 752 views | 0 times favorited | 4 replies | ![]() |
I know that a 80 th blade is used on Melamine or thin veneered plywood but is 3/4 cabinet grade birch ply to much for the blade to handle??? -- Lou, Florida |
#1 posted 05-21-2013 11:35 PM |
Wouldn’t be my choice, that is if you have a choice. But it will cut it fine, just a little more resistance.u |
#2 posted 05-22-2013 12:19 AM |
It depends on the blade (and the saw)...they’re not all created equal even if they have 80T, but a lot of plywood blades have 80 teeth. Be sure it’s clean and sharp, and it should be fine if it’s a decent blade. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#3 posted 05-22-2013 02:52 AM |
and put painters tape over your cut line to reduce tear out. |
#4 posted 05-22-2013 03:43 AM |
The biggest need for using the 80 tooth blade would be for cross cutting the plywood so as to minimize tear out of the thin veneer. Since plywood has wood running both directions there is no real wood grain, but there should me more wood running in the direction of the face than across the plywood. You may notice a little more resistance when ripping the plywood. I try to only use my crosscut blade when actually cross cutting plywood. For everything else I use my ripping blade. -- Bill M. "People change, walnut doesn't" by Gene. |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28052 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4755 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
