Can I flatten this?
Forum topic by muleskinner posted 05-21-2013 08:55 PM 1112 views 0 times favorited 16 replies Add to Favorites Watch
View muleskinner's profile
muleskinner
896 posts in 2344 days
05-21-2013 08:55 PM
This is a pie crust table that sat in my parents living room for as long as I can remember. For the last few years it has sat in my sister’s garage. When she pulled it out, this was its condition.
Is there any chance of salvaging it.
I’m pretty sure it’s mahogany veneer and core. The veneer on the bottom has come loose but I think I can deal with that. What is making me dubious is that the bottom tier has curled on one side. The other side and the top tier are still flat. My initial thought was to clamp a couple sets of cauls across it and tighten over time. Is that approach going to be effective?
-- Visualize whirled peas
16 replies so far
13594 posts in 3248 days
#1 posted 05-21-2013 09:41 PM
can’t hurt to try
won’t be any worse than it is already
maybe spritzer some water (on the bottom)
from time to time
make the bottom swell up some
good luck
View oldnovice's profile
oldnovice
6550 posts in 3275 days
#2 posted 05-21-2013 10:42 PM
Not to be glib … oh yes, to be glib and to take a word from the old TV show Happy Days ”sit on it”
I think you have a nearly impossible task ahead of you!
View madts's profile
madts
1842 posts in 2247 days
#3 posted 05-21-2013 11:01 PM
I would take the top off. Sand the bottom top to open up the pores, mist it with water and put it in the sun. Keep an eye on it. It might bough the wrong way. If that is the case do the opposite.
-- Thor and Odin are still the greatest of Gods.
muleskinner
#4 posted 05-21-2013 11:35 PM
David, I’ve been trying to figure out the process that made it curl in the first place. So far I’m thinking that sitting in the garage, maybe the dankness (a concept, being in NM, you’re probably blissfully unaware of but that we of the PacNW are congenitally familiar :)) worked its way between the bottom veneer and the core. If that’s the case wouldn’t adding moisture to the bottom just increase the curl?
Hans, “nearly impossible” means it’s possible, right? :)
View Don W's profile
Don W
18606 posts in 2475 days
#5 posted 05-21-2013 11:49 PM
if it comes apart you could try laying it on some damp grass in the sun. I’ve had it work for some lumber. I never tried a finished piece, but it may work.
View shipwright's profile
shipwright
7895 posts in 2705 days
#6 posted 05-21-2013 11:54 PM
If it were me I’d find some matching veneer, trace a pattern from it, and make a new one with a more stable substrate than was used by the original manufacturer.
This looks a lot like one of those places where you might be able to fix it if you are willing to spend twice the time and then put up with “almost as good as new” (or worse).
116906 posts in 3484 days
#7 posted 05-22-2013 12:41 AM
I don’t think there’s a lot of hope for straightening this out . I guess if I were going to try I think I might try steam and then clamping it flat.
View WDHLT15's profile
WDHLT15
1722 posts in 2383 days
#8 posted 05-22-2013 02:27 AM
I hope there is hope, but I don’t think so.
muleskinner
#9 posted 05-22-2013 03:09 PM
So it appears the consensus is that rescue is a quixotic quest. And in that tradition I think I’m going to carry on. I’m going to try putting some clamp pressure on it with a sandwich of plywood and a couple sets of cauls, stick it out in my pumphouse, check it every once in a while and see what happens. Maybe by fall it can be eased back into shape or you can all say “we told you so”.
Thanks all.
View redSLED's profile
redSLED
790 posts in 1800 days
#10 posted 05-22-2013 03:17 PM
Table top is toast!
Cut the top into 1” squares, mill each side square, then glue them back up randomly into a table top on top of MDF slab. Cut to size, mill and refinish as desired. That is, if you have nothing else to do.
View Sergio's profile
Sergio
468 posts in 2600 days
#11 posted 05-22-2013 11:30 PM
Just an idea: dismantle the whole thing apart, save the legs and posts and make new tiers for it…
-- - Greetings from Brazil - --
View bondogaposis's profile
bondogaposis
4611 posts in 2258 days
#12 posted 05-22-2013 11:42 PM
Pretty hopeless I’d say. But you may as well try to clamp it flat, while you make plans to make another top.
-- Bondo Gaposis
View pintodeluxe's profile
pintodeluxe
5568 posts in 2720 days
#13 posted 05-22-2013 11:54 PM
Should be fine, just run it over the jointer a couple times.
You have a 36” jointer , right?
I would keep the memories, and part with the pie table.
View Straightbowed's profile
Straightbowed
717 posts in 2205 days
#14 posted 05-23-2013 12:00 AM
looks like you need some of that table magic stuff spray it on turn out the light count to 126 and turn the light back on
-- Stevo, work in tha city woodshop in the country
View Dallas's profile
Dallas
3599 posts in 2394 days
#15 posted 05-23-2013 01:13 AM
Sure, it should be easy enough to flatten with the proper tools…..
...... just sayin.
