Grizzly G1276 Disc Sander; Oval to round connector for dust collection
Forum topic by Escritar posted 05-21-2013 07:29 AM 1903 views 0 times favorited 3 replies Add to Favorites Watch
View Escritar's profile
Escritar
2 posts in 1801 days
05-21-2013 07:29 AM
Topic tags/keywords: grizzly g1276 beltdisc sander disc sander dust collection
I’m searching for a solution to connect the oval dust port below the 12” disc on the Grizzly G1276 Belt/Disc sander to a dust collection system. I am aware Grizzly has changed 2010 and newer models to allow the use of a dust port on the front lower disc guard.
Has anyone found and/or successfully adapted an “oval to round” sheet metal fitting to the bottom oval dust port on models that were made before 2010?
3 replies so far
View crank49's profile
crank49
4030 posts in 2940 days
#1 posted 05-21-2013 01:57 PM
A good sheet metal shop can make one for you. They have to know the length and width of the “oval” and the diameter of the round you want to connect to and the desired length of the transition piece. They can make this out of whatever gauge material you want; thicker costs more naturally. I’ve had several made over the years and the cost is surprisingly low; probably less than $30. I had one made for a wood stove flue connection once for $7.00.
View wiswood2's profile
wiswood2
1138 posts in 3665 days
#2 posted 05-21-2013 05:52 PM
I used a short piece of flex hose with a hose clamp and it formed it self to oval on the oval end.
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
View AandCstyle's profile
AandCstyle
3027 posts in 2226 days
#3 posted 05-22-2013 01:22 AM
Chuck
+1
-- Art
