Drum Sander
Forum topic by warden4u posted 05-21-2013 07:29 AM 1692 views 0 times favorited 22 replies Add to Favorites Watch
View warden4u's profile
warden4u
13 posts in 1882 days
05-21-2013 07:29 AM
I’M NEW AT WOODWORK. I WANT TO BUY A DRUM SANDER? DO YOU HAVE A DRUM SANDER? IF SO TELL ME WHAT KIND IT IS AND HOW DOES IT WORK ON SANDING RAW MATERIAL? I’M OPEN TO ANY SUGGESTION. I NEED HELP NOT TO BUY THE WRONG ONE.
G0458 18” 1-1/2 HP Single-Phase Open End Drum Sander or G1079R 16” Drum Sander w/ Rubber Conveyor what is your suggestion?
-- Charles, Kiefer, Oklahoma, http://www.woodworker.com
22 replies so far
5013 posts in 2543 days
#1 posted 05-21-2013 12:49 PM
I have one, and it’s definitely earned it’s keep in my shop. Mine is a Delta 18/36, one of the first ones and I’ve had it about 12 years. But with your opening statement about being “new to woodwork”, I’m wondering if you have the more often used tools in your shop (?). The table saw, maybe jointer and planer, bandsaw, several others will get more use than the drum sander. They work very well on “raw wood” (unfinished?), but they work very slowly. You can’t hog off material, and you (IMHO) you need a DC to use one, they generate mountains of very fiuns dust. They are not finish sanding machines, you will likely have scratches that need to be removed with an ROS or such, As for make, were I to buy one today it would be a Jet (previously Performaxx) or maybe the Supermax model.
View Albert's profile
Albert
510 posts in 3639 days
#2 posted 05-21-2013 12:55 PM
I agree with Fred, I could not work without it but it does have many limitations as he says. Mine is the Delta and it is a ‘love/hate/ relationship. I would rate it as being just ok.
Paul
View agallant's profile
agallant
551 posts in 2936 days
#3 posted 05-21-2013 01:05 PM
I only need three tools. Tablesaw, Router, and Drum Sander. I have the Jet 16-32. They take some time to setup properly so it sands evenly and wrapping the drum is a bit of an art. With that said it is one of the most important tools I have in my shop.
View crank49's profile
crank49
4032 posts in 3021 days
#4 posted 05-21-2013 01:17 PM
Unless you meant to be yelling, turn off the CAPS LOCK.
I, too, wonder what you have as a background for the sander.
What other equipment do you have?
What kind of working space do you have?
What kind of dust collection do you have?
What type of work do you plan to do with it?
These are not just being nosy, but are relevant to the advise we could give.
View skipj's profile
skipj
97 posts in 2322 days
#5 posted 05-21-2013 01:48 PM
I agree with Fred. I have the supermax and love it. I’m into my 6th kitchen remodle in as many months.
All my material is bought in the rough meaning it goes to the table saw,jointer. planer and sander
in that order.
View JamesT's profile
JamesT
102 posts in 1962 days
#6 posted 05-21-2013 02:23 PM
wardun4u,
If you consider a Delta 18-36, Models 34-250 – 34-260X you should be aware there are two plastic miter gears used for table elevation that are no longer available, (even for the newer 34-260X). If one of the teeth should chip or get damaged there is no replacement parts available from any delta parts supplier, and Delta considers the parts “obsolete”.
I don’t know anything about the Grizzly. Recommend you also look at the Jet or Performax.
-- Jim from Doniphan
View bannerpond1's profile
bannerpond1
397 posts in 1949 days
#7 posted 05-21-2013 02:29 PM
I have the Jet 16-32 drum sander. It is a real pain to change the roll due to the cramped space where you have to blindly push the end of the paper strip. If you don’t get it tight enough, the paper will overlap and produce burn marks.
As for “raw material,” if you use the drum sander on finished wood, you will gum up the paper and make it unuseable for the next job.
Still, I use the drum sander a lot, but always use the ROS afterward, because even 150 paper on the drum makes scratch marks. You will have to use the ROS or it’ll look really bad under a finish.
-- --Dale Page
View Loren's profile
10476 posts in 3698 days
#8 posted 05-21-2013 03:19 PM
I’d recommend a closed-end sander. Less fussy
to work with.
There are a lot of used drum sanders on the secondhand
market because people buy them and get frustrated
or otherwise stop using them.
View Sergio's profile
Sergio
470 posts in 2742 days
#9 posted 05-21-2013 03:24 PM
You are new to WW and already know that you need a drum sander? What kind of projects do you intend to do?
-- - Greetings from Brazil - --
#10 posted 05-21-2013 03:29 PM
Jim, your point is valid about the gears, but there is a workaround. This gear can be modified to work as a replacement…I found this info on another forum, but it was posted originally over at SMC (I don’t visit that forum) Here's the link to the discussion. Please don’t consider this as me pimping for the Delta sander….but it might be useful to someone who broke that gear.
View moke's profile
moke
1186 posts in 2826 days
#11 posted 05-21-2013 05:13 PM
Warden..
I too have a supermax…it is a great tool, well worth every penny. It is designed by the same guys that designed the Jet, only 20 years later, they went back and corrected there original complaints with the original performax. Having said that, I agree with everything that has been said about why you want a drumsander?
If you have all the “staples” for tools and have the money I say, “WTH” but if this is a purchase ahead of router tables with lifts, a good TS, dp….etc…I would say let this be one of your last accquisitions.
Also be aware, a Drum Sander (DS) is not a replacement for a planer. They compliment each other, not replace…
IMHO, keep in mind that you do not want a DS that the table goes up and down on, as opposed to the sanding head. I can’t remember, but I thought the grizzly open end units raised the table.
Good Luck,
Mike
-- Mike
warden4u
#12 posted 05-21-2013 09:07 PM
I DONT LIKE SANDING ALL WOOD TO GET STARTED ON WHATEVER I CHOOSE TO DO. I HAVE MADE OTHER PRODUCTS BIRDHOUSES, PLANTERS, CABINETS, AND BEDS. BUNK BEDS, DESK. SHELVES. I WANTED TO GET A JUMP ON THE SANDIND BEFORE THE FINAL TIME. SO I WANTED TO BUY DRUM SANDER TO HELP GET WOOD BE CLOSER TO FINISH IN STEAD SAND BY HAND. WARDEN4U
I HAVE 20’ GRIZZLY PLANER, 17 ’ GRIZZLY BANDSAW CRAFTSMAN 10” TABLESAW, PALM SANDE,R DRILLPRESS DUST COLLECTOR.
View DrDirt's profile
DrDirt
4426 posts in 3792 days
#13 posted 05-21-2013 09:23 PM
Check out Stumpy Nubs site – and there are videos and ultimatly a set of plans to build one.
#14 posted 05-21-2013 09:31 PM
I doubt any of us can say we “like” sanding either, but a good ROS is going to be more useful…IMHO, of course.
JamesT
#15 posted 05-21-2013 09:59 PM
Fred,
I started the thread you’re referring too. My whole point was that you should not have to find a gear that works after it’s modified. Delta still sales this sander (34-260X) and some parts are not available. That’s completely inexcusable. IMHO
