a strange jig idea.
Forum topic by ttewelca posted 05-21-2013 07:29 AM 1645 views 0 times favorited 11 replies Add to Favorites Watch
View ttewelca's profile
ttewelca
9 posts in 2041 days
05-21-2013 07:29 AM
Topic tags/keywords: jig question
Hello everyone,
I work at a furniture shop; I don’t make the stuff unfortunately, but I do fit the ironmongery. When I mark out for the handles I use a template that one of my colleagues made. As it’s only a piece of mount board, it’s not very accurate and there are no stops or anything. It takes a long time to mark out all the handles as a result. Don’t get me wrong, it works, but it’s not very efficient and we have a lot of furniture coming through sometimes.
I’m quite curious as to if I can make a small jig that makes this easier and quicker. I had the idea of a board with the holes drilled through. 4 sliding stops, 2 of which (being the top 2) sliding together to centralise it horizontally, and the remaining two sides sliding both together and Independently of each other. to centralise on small drawers and to line one side if it’s wider.
I hope that gives a reasonably clear idea of what I mean. Any suggestions will be greatly appreciated to point me in the right direction.
Thank you,
Andrew
11 replies so far
View Kaleb the Swede's profile
Kaleb the Swede
1835 posts in 1991 days
#1 posted 05-21-2013 11:06 AM
Hi there Andrew, I’m new around here and a new wood worker. I’m not the guy to be answering your questions but if you provide pictures there are some amazing wood workers with a ton of experience that could take a look and offer ideas/suggestions. We like pictures. Maybe show how you want thing mounted? Hope this helps
-- Just trying to build something beautiful
View Danpaddles's profile
Danpaddles
573 posts in 2334 days
#2 posted 05-21-2013 11:32 AM
View NoLongerHere's profile
NoLongerHere
893 posts in 2698 days
#3 posted 05-21-2013 12:57 PM
I don’t trust jigs for door pulls, if that’s what you’re referring to. Too much slop in the hole and no last chance to double check before drilling. It only takes one little hole in the wrong place to blow the hardware install and will cost lots of time and money.
I use two 6” combination squares, one for the vertical (centered?) mark and one for the side measurement.
I put a little piece of blue tape on the drawer fronts first to mark on. Layout all the handle locations and get the clients approval, if possible before you drill. Use a block of wood to back up the drill hole.
It’s just as fast as making multiple jigs for different drawer sizes and hoping you picked the right guide hole.
If ever the rule: “measure twice, drill once” applies, it’s on this last step. I haven’t drilled a door wrong in 20 yrs.
View Gene Howe's profile
Gene Howe
10520 posts in 3450 days
#4 posted 05-21-2013 01:11 PM
Danpaddle’s link to that commercial jig looks like the solution. A large shop, fitting numerous sized drawers, would recoup the cost fairly quickly.
In my experience, with limited numbers of drawers at one time, I find reedwood’s method the most efficient…..and cost effective.
ttewelca
#5 posted 05-21-2013 10:18 PM
That jig is basically what i mean yes, thanks.
It’s only a small shop with about 3 of us working there, we just finish the stuff off before we deliver it. It’s more for my own curiosity than anything. I’ll try and remember to take a picture of the thing we’re using currently.
we don’t have to drill them which is fortunate, the wood is so soft you can just screw straight into it but holds very well.
thanks for the replies
View Loren's profile
10476 posts in 3670 days
#6 posted 05-21-2013 10:34 PM
View madts's profile
madts
1862 posts in 2362 days
#7 posted 05-21-2013 11:07 PM
Are you guys using CNC machines? If so get the designers to have the machine drill the holes.
-- Thor and Odin are still the greatest of Gods.
View nzmerlin's profile
nzmerlin
28 posts in 1896 days
#8 posted 05-22-2013 12:06 AM
Don’t know if I can post this here but this came from Woodsmith Tips and techniques
https://www.filesanywhere.com/fs/v.aspx?v=8b6a648a5d6575779ea0
Merlin
-- No! Try Not. Do, or do Not.There is no Try.
ttewelca
#9 posted 05-23-2013 09:18 PM
haha nothing quite so fancy madts. it’s canadian pine, rustic furniture, very low tech approach. we’re only a 3 man company and we source the furniture from two other workshops we use. we just, or more I, fit the handles and cupboard hang the doors in the shop.
thanks for the two ideas loren and nzmerlin, they’re both what I meant
View Bill White's profile
Bill White
4947 posts in 3982 days
#10 posted 05-23-2013 09:27 PM
My only issue with commercial jigs is that they don’t often allow function on doors and drawers with any raised molding.
I often make a special (read that thin ply and an edge guide) jig that will accomodate the reveal for the molding.
Your thoughts??
Bill
-- bill@magraphics.us
ttewelca
#11 posted 05-25-2013 04:22 PM
fortunately the drawers we use don’t have any moulding on them so it’s not an issue, although i do see the dilemma.
