Festool Domino
Forum topic by Woodenwizard posted 05-20-2013 11:44 PM 7737 views 0 times favorited 12 replies Add to Favorites Watch
View Woodenwizard's profile
Woodenwizard
1325 posts in 2945 days
05-20-2013 11:44 PM
I am considering the purchase of a Festool Domino system. It is pretty pricey and I don’t have the funds to purchase the Festool dust collection system also. So my questions are do you need the dust collection system? Can a typical shop vac. work with the domino? Any good tips or things to know about the domino system?
Any words of wisdom would be greatly appreciated.
Thanks
John
-- John, Colorado's (Wooden Wizard)
12 replies so far
View RockyTopScott's profile
RockyTopScott
1186 posts in 3380 days
#1 posted 05-20-2013 11:58 PM
I use the Dust Deputy with a wet/dry vac and the Festool hose and it works well.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View Loren's profile
9931 posts in 3550 days
#2 posted 05-21-2013 12:23 AM
Bosch VAC005 German made hose should work with it.
The hose will fit a regular shop vac port (2.5” I think)
and is compatible with most of the Festool tools on the
other end.
404 - Not Found
2544 posts in 2871 days
#3 posted 05-21-2013 12:38 AM
I don’t see why any shop vac wouldn’t do the same job, though more noisily and with less style, you could try one of these
http://www.axminster.co.uk/axminster-numatic-stepped-hose-reducer-prod208855/
View tturner's profile
tturner
63 posts in 1930 days
#4 posted 05-21-2013 01:53 AM
You can get a festool hose to fit a common shop vac and you can also just buy the hose end to fit your hose. However you must have dust collection with that tool or it will never work correctly. You really can’t beat that tool. I’ve had mine for years and love but can’t justify the big new model. With a large domino its about 90% the strength of mortise joint and about 90% faster. Good luck!
Todd
-- I'm him
View RonInOhio's profile
RonInOhio
721 posts in 2766 days
#5 posted 05-21-2013 01:54 AM
The Festool hose costs around 140 dollars if I’m not mistaken.
Not in my budget.
View waho6o9's profile
waho6o9
8098 posts in 2479 days
#6 posted 05-21-2013 02:07 AM
Some folks make their own Dominos out of the lumber
from their projects, that way the contraction and expansion
would be the same rate.
Have fun with Domino should you purchase it.
View josephf's profile
josephf
182 posts in 1998 days
#7 posted 05-21-2013 02:10 AM
saw a bosch hose on amazon recently for 40$ .Would of been a good buy . Try a junk store ,get a small flexiable hose and then fit it to your vac and the domino .
View Matt Przybylski's profile
Matt Przybylski
539 posts in 2280 days
#8 posted 05-21-2013 02:54 AM
As Loren mentioned, the Bosch vac will work with it: http://www.amazon.com/Bosch-VAC005-5-Meter-Vacuum-Hose/dp/B0000AV78B/ref=sr_1_1?ie=UTF8&qid=1369104659&sr=8-1&keywords=Bosch+vacuum+hose
It’s the same as a festool hose but not anti static. I have this hose as well as the festool hose/ct36 and the domino. I normally connect the hose to the dust deputy and the dust deputy to the CT but you can go dust deputy to a shop vac. The downside of using a shop vac is no hepa filtration and no variable suction though with the domino you set it on high anyway.
Either way, the hose fitting on amazon is incorrect. If you look at the user photos you will see the actual hose fitting which is the same exact one as the festool hose. You can’t go wrong.
-- Matt, Arizona, http://www.reintroducing.com
View mcase's profile
mcase
446 posts in 3031 days
#9 posted 05-21-2013 04:27 AM
You will get stronger joints wth shop made smooth tenons. They glue up stronger and are way cheaper. Its also quite often advantageous to make wider mortises by adjoining your plunges. Make two side by side plunges near each other and a third to clear out the center to a wide mortise. A very useful tool. You absolutely need a vac. I got a cheap hose and hooked it up to a cheap Rigid vac and cheap auto swtch . Works fine. So dont waste money on the Festool acessories.
View RodNGun's profile
RodNGun
118 posts in 2205 days
#10 posted 05-21-2013 04:57 AM
Lots of good advice above. The price is insane until you start using the tool then you’ll be fine with it. Vac is mandatory, although Festool unit is not required. Too much suction can be a problem as the tool “sticks” to your work. I’m not a Festool hoarder, most stuff seems over priced and nothing special but the Domino is a fantastic tool.
View James 's profile
James
138 posts in 2828 days
#11 posted 05-21-2013 03:27 PM
I have had a domino for about 4 months now and I have note used it once. I might be the only domino owner who wishes they would have bought something else instead.
View AlanBienlein's profile
AlanBienlein
159 posts in 2576 days
#12 posted 05-21-2013 05:09 PM
I will have to agree on the cheaper ways to do mortises. I’m glad to see that I’m not the only one that built his own domino from the plans available online. I still prefer my horizontal slot mortiser and my panto router for mortise and tenon joinery.
