90 cabinet doors to strip paint!! How to do fast?
Forum topic by Adrian A posted 05-19-2013 05:40 AM 19672 views 0 times favorited 22 replies Add to Favorites Watch
View Adrian A's profile
Adrian A
169 posts in 2839 days
05-19-2013 05:40 AM
Taking on a job to refinish a kitchens latex painted cabinets. 90 doors and drawers!!! Ahhh.
I used chemical stripper, sandpaper , and card scrapers and it took like 2 hrs for one door.
What’s the quickest and best way to do it for such a large job?
22 replies so far
View AlaskaGuy's profile
3988 posts in 2245 days
#1 posted 05-19-2013 05:50 AM
You can buy paint grade doors pretty reasonable. No way I’d head down your path.
View kdc68's profile
2645 posts in 2213 days
#2 posted 05-19-2013 12:04 PM
+1 AlaskaGuy
Buying new would also give you a chance to make changes in the style of door and drawer fronts (ie from flat panel to an arched raised panel) . Another added bonus to renovating the kitchen….
-- Measure "at least" twice and cut once
View Buckethead's profile
3194 posts in 1805 days
#3 posted 05-19-2013 12:45 PM
What if this is for a client? Then our friend is stuck. My guess is they are raised panel doors if it took 2hours to strip one door. 2×90=180. Massive project.
Not something I do, but I might try a couple methods to speed the process. A belt sander, a power plane, outsourcing… THAT’S IT! Outsourcing!
-- Support woodworking hand models. Buy me a sawstop.
View skipj's profile
97 posts in 2209 days
#4 posted 05-19-2013 01:21 PM
I like what buckethead said, outsource AND i’ll take the job. At my hourly shop rate thats a nice chunk of change.I am doing a kitchen now. Refacing the face frames and building new drawers and doors.
View RockyTopScott's profile
1186 posts in 3415 days
#5 posted 05-19-2013 01:28 PM
Soda blasting. If you do this alot, it will save time and $$$
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
13598 posts in 3277 days
#6 posted 05-19-2013 01:44 PM
find a furniture stripper company
one with a ‘dip tank’
so much for a sq. ft.
they dip
strip and brush
and rinse them
you just need to lightly sand to knock down the raised grain
before your new finish
get a bid
and add your cost for it too
Adrian A
#7 posted 05-19-2013 02:33 PM
Here’s a picture of one section of cabinets and the finished product. It took at least an 2 hours for that one door.
#8 posted 05-19-2013 02:39 PM
Adrian A.... I retract my previous post about buying new….and changing the style…. That is a beautiful door….Hopefully you find an efficient and fast method to strip the paint. Others have posted sending them out to be stripped. That may be the best method in terms of their cost versus your time
View cabmaker's profile
1707 posts in 2745 days
#9 posted 05-19-2013 03:10 PM
How about new doors, much quicker.
Adrian A
#10 posted 05-19-2013 03:29 PM
He likes the ones he has and I’d rather save on lumber and just refinish them. More profit : )
View Charlie's profile
1100 posts in 2222 days
#11 posted 05-19-2013 03:44 PM
Try a heat gun. Aside from vat stripping by a pro stripping shop, I don’t see any way around you having to diddle around with the profile. But a heat gun might peel latex right off. Depends how many coats and what was on it BEFORE the latex.
Oh and I’ve seen vat stripping really mess up stuff. But might be your fastest option.
View derosa's profile
1572 posts in 2772 days
#12 posted 05-19-2013 03:50 PM
Heat stripping if it is just latex may be the best way. Small heat gun and a very stiff bristle brush to grab the paint as it bubbles. Otherwise the soda blasting doesn’t sound like a bad idea, pick up a cheap kit and try it.
-- --Rev. Russ in NY-- A posse ad esse
View oldnovice's profile
6693 posts in 3304 days
#13 posted 05-19-2013 04:46 PM
When I did that a long time ago I sent them out to get stripped. As long as they are solid wood and not PB veneered they can tank strip them. Mine turned out beautiful. This was back in Illinois in my second house about 25 years ago!
View ,'s profile
2387 posts in 3483 days
#14 posted 05-19-2013 05:43 PM
we recently stripped face frames in a kitchen with simple paint stripper, no problem. Since we can build a set of doors in our shop we could almost build new doors easier than stripping.
But in the past we have built a small shallow tub out of wood scraps and lined it with plastic tarp and filled it with lacquer thinner in order to strip a set of stain grade doors. Maybe submersion of the door inside paint stripper or lacquer thinner will help.
i am glad i dont have your job.
404 - Not Found
2544 posts in 2905 days
#15 posted 05-19-2013 09:19 PM
I would send out a test door for chemical stripping and make a decision about how to proceed when you get it back. If the paint won’t come out of the pores, you will still be left with lots of sanding. Same with stripping with a heat gun, try it first and see if that will work. The scrapers you have, have you got one shaped to the inside moulding? If not you could make one, might speed you up a bit. Nice job on the refinished door btw.
