Question regarding riveting
Forum topic by Matt Przybylski posted 05-18-2013 10:15 PM 1490 views 0 times favorited 20 replies Add to Favorites Watch
View Matt Przybylski's profile
Matt Przybylski
546 posts in 2378 days
05-18-2013 10:15 PM
Topic tags/keywords: rivet rivet gun
I bought a rivet gun from Harbor Freight and overall it seems to work well (it got good reviews on their site: http://www.harborfreight.com/heavy-duty-17-1-2-half-inch-hand-riveter-with-collection-bottle-66422.html). I riveted some plastic from a pop bottle today to my separator trash can and the rivets came out well on the front but the back they’re a bit “mushroomy”. I was under the impression that both front and back would be nice and flat against the trash can. Am I doing something wrong or is this how rivets look on the back side? This is my first time riveting anything, ever, so please be gentle in calling me a newb :)
Front:
Back:
-- Matt, Arizona, http://www.reintroducing.com
20 replies so far
View Loren's profile
10401 posts in 3648 days
#1 posted 05-18-2013 10:18 PM
No. That’s what they do. You can hammer them flat after
though. You have to back up the other side with a
sandbag or hunk of metal to do it well.
Matt Przybylski
#2 posted 05-18-2013 11:30 PM
Gotcha, makes sense. Glad it’s not the tools fault cuz I quite like it actually. I’ll hammer the next ones I do if they need to be flattened, these really don’t plus I already put hvac tape on the joints to seal them. Thanks for letting me know.
View Dallas's profile
Dallas
3599 posts in 2487 days
#3 posted 05-18-2013 11:40 PM
If they need to be flat on the inside, rivet from that side.
Smacking them with a hammer to flatten them is going to loosen them up.
If you want flat rivets on both sides use real, solid rivets with the proper tool and bucking bar.
View poopiekat's profile
poopiekat
4355 posts in 3734 days
#4 posted 05-18-2013 11:43 PM
Loren’s right! You can minimize the amount of schmooshed-over backside by selecting POP rivets that closely match the thickness of the two materials you’re joining together. What I see in your photo looks like it would require only a POP rivet with a 1/8” depth, and it looks like you’ve used 1/4” Good work, though!
I’m more uncomfortable with a Harbour Freight review on one of their own tools. That’s gotta be word play and semantics at its finest.
View taoist's profile
taoist
124 posts in 2491 days
#5 posted 05-18-2013 11:58 PM
Maybe one of the reasons they mushroomed was because those are what’s called blind rivets, pop rivets, or Cherry Max rivets. The only rivets, that I know of, that use use a rivet gun for installing are solid rivets and are different than the ones in the pictures.
You also need a rivet set of the proper type for the rivets and air hammer/rivet gun you’re using and finally you will need a bucking bar for the opposite end from the head.
The ones in the pics use a manually operated gun or a hydraulic pneumatic pulling device to pull a stem through the rivet sleeve to spread it and then break off at the proper torque. The ones (pom) rivets don’t get installed with an air hammer.
poopiekat
#6 posted 05-19-2013 12:04 AM
I wouldn’t use any type of percussion force. It’s only a trash can, not a steel beam. Matt P. made the right choices, right tool, and did the right thing.
Matt Przybylski
#7 posted 05-19-2013 12:07 AM
Quite honestly I’m not going to go crazy riveting things all the time, just the occasional task like this, so I didn’t want to go crazy spending money on something that will be seldom used. Appreciate all the feedback though, always good to learn new things like what a bucking bar is and the fact that such a thing even exists :) can never have too much knowledge.
View Moron's profile
Moron
5032 posts in 3893 days
#8 posted 05-19-2013 12:18 AM
rivets
why ?
I prefer duct tape and dap
Shawn Masterson
1325 posts in 1948 days
#9 posted 05-19-2013 12:19 AM
you can also use backer washers. they will hold the plastic better.
Moron
#10 posted 05-19-2013 12:26 AM
rivets might as well be forever
duct tape
easy breezy cover girl and a screw do magic
View OnlyJustME's profile
OnlyJustME
1562 posts in 2377 days
#11 posted 05-19-2013 12:29 AM
I second the use of backer washers with riveting plastic. Some plastics will start cracking around the rivet due to the point load in such a concentrated area. the washer would spread it out more reducing the chances of cracking. Don’t think you will have a problem with the pop bottle plastic. just some info for future use. :)
-- In the end, when your life flashes before your eyes, will you like what you see?
View HorizontalMike's profile
HorizontalMike
7757 posts in 2914 days
#12 posted 05-19-2013 12:34 AM
Why not just use a tube of E6000 adhesive? Great stuff and sticks to just about everything. You can also get it in clear. This stuff is amazing. I have bought it in electronics stores, HD and others.
http://www.eclecticproducts.com/e6000_retail.htm
Matt Przybylski
#13 posted 05-19-2013 12:38 AM
I thought about using construction adhesive but the pop bottle made the plastic just roll right up and I couldn’t get it straightened out. I used rivets because 1) i wanted to try rivets out and why not on this? if it failed no biggie, no harm done and 2) i thought the rivets would hold the plastic in place while I was able to put hvac tape around it, which is exactly what they did :)
Moron
#14 posted 05-19-2013 12:44 AM
dap
I’ve seen a thousand rivets drilled/popped/sunk and drilled a thousand out, from 10 cents a rivet to 300 dollars a rivet
jus sayn
easy breezy uncomplicated tape is often less expensive then commitment.
Moron
#15 posted 05-19-2013 12:46 AM
construction adhesive is even worse then a rivet
2 cents
