Drawer front issue - problem solved!
Forum topic by Sandra posted 05-18-2013 02:38 AM 1728 views 1 time favorited 30 replies Add to Favorites Watch
View Sandra's profile
Sandra
7207 posts in 2160 days
05-18-2013 02:38 AM
I’m making progress on my Not So Big Workbench from Fine Woodworking.
I spent the better part of today wrestling with a big ole slab of walnut. Resawing it was no a pleasant endeavour, but I got it done.
In the picture, I just have the drawer fronts stacked up on each other so that I don’t mess up the order. In doing so though, it looks like they are not going to be square to the drawer boxes. Then it occurred to me that I did sand down the bottom supporting stretcher, because one corner of one of the drawer boxes was catching.
That could cause one of the drawer boxes to be sitting off kilter, but both boxes are off…
So where do I go from here? Do I just adjust the space in between the drawer fronts to accommodate the angle?
The plans call for installing the pulls next, but I don’t want those to look ‘off’ either.
Any suggestion are appreciated. Once this sucker is done, I know it will get used and abused, but I’m learning a lot by building it and want to get it right.
Thanks
-- No, I don't want to buy the pink hammer.
30 replies so far
13624 posts in 3426 days
#1 posted 05-18-2013 02:56 AM
if the drawers themselves are working ok
the fronts can be brought to square to look right
even if the top and bottom one
need to be slightly tapered to fit the face frame
you might have to use slightly thicker shims
to get the look you want balanced all around
i usually get them all lined where i like them
with the shims in place
and removing the top ones down
place their corresponding shims with each front
in the place they belong for later
so they don’t get mixed up
and starting with the bottom one
use double tape to secure it there
and add the next shims for the second one up
and tape it too
and the top one too
then carefully opening the drawers and using some clamps
to hold the face tight to the drawer
pilot from the back and screw the drawer to the front
with the right sizes screws
a few whacks with a rubber mallet if needed here or there
after you like it then do the handles
many might need longer machine screws than what comes with the handles
there are special hardware and screws to do this out there
but for these drawers not worth the trouble
unless you get in bulk and have that for other later builds
View Dave's profile
Dave
11429 posts in 2925 days
#2 posted 05-18-2013 03:00 AM
Sandra I am going to assume a bit.
You drawer carcases are separate from the fronts.
If they are and work smoothly in the carcass. Set the fronts all in like you have pictured and start from the bottom.
I would get the placement and spacing set on the bottom ones. Then attach the drawer case to them while they are set in the carcass. Then do the middle ones and do the same. Then the top.
You have to get the spacing right or they will look OFF. They look pretty close.
You will have to work with what you have and hope the grain direction works out. You only have a little fudge room to remove with a plane.
I hope that makes sense.
What you are doing is one of the hardest things to learn. Like setting a house door for the first time.
View Dave's profile
Dave
#3 posted 05-18-2013 03:01 AM
David was typing while I was.
What he said.
Sandra
#4 posted 05-18-2013 03:04 AM
Thanks so much. That makes perfect sense.
I had considered tapering the drawer fronts, but it hadn’t occurred to me to just do the top and bottom ones. The centre one would be too obvious. The recessed drawer pulls I’m using are square also. Rather than putting them on now, I think I’ll follow your advice, do the pilots, mark for the pulls and go from there.
The shims in the picture were put there just to see how far out of square the fronts were.
View DIYaholic's profile (online now)
DIYaholic
19634 posts in 2760 days
#5 posted 05-18-2013 03:06 AM
What they said!!!
BTW: That WILL be a sharp looking work bench!!!
View Dave's profile
Dave
#6 posted 05-18-2013 03:06 AM
Chad has a good tip.
#7 posted 05-18-2013 03:13 AM
also if you taper the bottom one
do both sides together
and make sure they are straight across the top
then on up the same
don’t want one side right
and the other looking ok too
but not in line with other side
the dark lines between them will expose everything
it wants to look even everywhere
View DocSavage45's profile
DocSavage45
8657 posts in 2927 days
#8 posted 05-18-2013 03:13 AM
Some adjusting can be done with a hand plane to true it up if you are wanting it perfect. But no one will notice the imperfections but you. Otherwise you have good directions from Dave and David. Sounds like a Broadway musical team. LOL!
You have come a long way!
-- Cau Haus Designs, Thomas J. Tieffenbacher
Sandra
#9 posted 05-18-2013 03:14 AM
The drawers and the fronts are separate. There are two large boxes that hold three drawers each, and the drawers are all hung and work well. I know that the fronts don’t have to be perfectly square to the drawers themselves, but they are not square to the carcass.
Trying to upload a picture…
Sandra
#10 posted 05-18-2013 03:15 AM
Sandra
#11 posted 05-18-2013 03:16 AM
I’m thinking this is where something went wrong…. I drug those boxes out of the carcass and shoved them back in so many times, I must have knocked them out of square.
Thanks again gents.
View waho6o9's profile
waho6o9
8295 posts in 2662 days
#12 posted 05-18-2013 03:26 AM
Impressive progress Sandra, congratulations on your persistence
and the growing of your woodworking skills!
DocSavage45
#13 posted 05-18-2013 04:15 AM
You probably know to check diagonally from corner to corner.
View StumpyNubs's profile
StumpyNubs
7636 posts in 2885 days
#14 posted 05-18-2013 12:03 PM
The first thing I would do is take those shims out. They look messy. I’m surprised you didn’t know that you were supposed to remove them when you were done. And it looks like you forgot to put on the knobs too…
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
Sandra
#15 posted 05-18-2013 12:50 PM
Coffee, Stumpy. Go pour yourself some coffee.
showing 1 through 15 of 30 replies
