Reliant Planer
Forum topic by WayneE posted 47 days ago 175 views 0 times favorited 5 replies Add to Favorites
View WayneE's profile
WayneE
5 posts in 56 days
47 days ago
Topic tags/keywords: reliant knifes planer
I have a Reliant model DD37, 15” planer that has not been used for sometime. I am trying to get it back in to shape. I have been attempting to remove the knifes and have been met with resistance in getting the set bolts to loosen. Has anyone got ideas on how to best go about getting these knifes out? Also looking for a source to purchase parts.
Wayne
6716 posts in 388 days
47 days ago
Have you tried the manufacturer’s website?.
View fredf's profile
fredf
228 posts in 246 days
47 days ago
Wayne—When looking for parts for my Reliant jointer, I found that the gib screws for a grizzly appear to be the same. do your screws screw out of a clamp bar and wedge against the opposite side of a grove?? you need to turn the screws into the bar to loosen . . . . or do the screws go through the blade? ——- have you tried liquid wrench or wd-40 etc
up untll a couple of months ago Woodworker's Supply was offering parts on a best effort basis, but apparently they have just dropped that offer
Grumpy —Reliants were imported by woodworker’s warehouse which folded a couple years ago.
-- Fred, Springfield, Ma
View BeechPilotBarry's profile
BeechPilotBarry
410 posts in 239 days
47 days ago
I like PB Blaster for stuck bolts. It’s cheap, available at any good auto parts store, and better than any well known product at freeing stuck bolts.
-- - Real men read directions
WayneE
5 posts in 56 days
46 days ago
The bolts screw out and clamp against the opposite side. Any idea where I would get replacement bolts?
Wayne
fredf
46 days ago
once you get then out see if they are 1/4 – 28 thread (careful there is a nearly identical metric thread that will screw in a couple of turns and bind) if so see http://www.grizzly.com/images/partslists/g0477_pl.pdf and see if key 172 is the right length
Bookmark And Share This Page
