Best Joint For A Picture Frame???
Forum topic by Brad posted 47 days ago 326 views 0 times favorited 7 replies Add to Favorites
View Brad's profile
67 posts in 310 days
47 days ago
I’m building a ton of picture frames for my wife and I’m wondering what the best way to join the corners are. Any suggestions guys?
- Brad
-- Great Coffee= 8oz strong coffee, 1tbsp brown sugar, 1tbsp 1/2&1/2, 1 heaping teaspoon mahoganny
View Brad's profile
47 days ago
Oh the stock for the pictures is 3/4”x1”x20”
teenagewoodworker
2135 posts in 305 days
47 days ago
i would suggest a mitered bridle joint
Click for details
just go to the project page and it will show a close up of the joint. works wonders!
View lew's profile
lew
1748 posts in 292 days
47 days ago
Another similar joint from Denis’s suggestion would be a spline joint.
You indicated you were making a bunch of these. You could make a spline cutting jig so that the process could be a little faster.
View 8iowa's profile
8iowa
187 posts in 298 days
47 days ago
Good comments here. I’ll add the importance of setting your miter gauge truly at 45 degrees. An accurate protractor is a good investment. Also, use a 60 or 80 tooth crosscut blade for smoother cuts and a stop block on an extension of your miter gauge to insure that opposite sides of the frame are exactly the same length.
View Joe Lyddon's profile
Joe Lyddon
170 posts in 589 days
47 days ago
A Half-lap is nice… but not as strong as the others mentioned… but, with Today’s glues, would be very good.
The Shakers used a COOL through mortise & tenon, which I think is really COOL…
-- Have Fun! Joe Lyddon - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=1389"
View Eric's profile
Eric
705 posts in 320 days
46 days ago
Or mix it up! My very very first woodworking project was a butt-joint picture frame. The interior and exterior strips were stained, and the interior strip was natural. Despite all I’ve learned since then, I have to say it’s a mighty purty frame.
-- Eric at http://adventuresinwoodworking.com
View DaveR's profile (online now)
DaveR
235 posts in 257 days
46 days ago
In the past I spent some time working in a picture frame shop. We just mitered the molding, glued and pinned the corners. Even on very large frames that was strong enough. The miters have to be very good and we used a chopper rather than a saw to cut them. I have a large watercolor done in the 1800’s. The frame is at least from the early 1900s. It is just miitered and still together after all these years. I expect it was glued with hide glue
I think a mitered half-lap would be more than strong enough because you would have fairly large faying surfaces that are long grain.
-- Quantum materiae materietur marmota monax si marmota monax materiam possit materiari?
Bookmark And Share This Page
