Another Cherry question.
Forum topic by Mark posted 05-16-2013 08:41 PM 1126 views 0 times favorited 12 replies Add to Favorites Watch
View Mark's profile
Mark
916 posts in 1998 days
05-16-2013 08:41 PM
Morning all. I getting ready to finish a cherry console table and I’m quite bumfuzzled about alllllll the different finishes available. I read the post from Quatzee re: Finishing his cherry boxes and either the Danish oil or the shellac sounds good. I’m thinking, if I went with the shellac I would go with an amber rather than the orange as I’m trying to keep the same tone as the 2 book cases I made, so a bit darker rather than orange I guess. But either will require a top coat of clear lacquer. Is that about right? Thank you.
-- Mark
12 replies so far
View PurpLev's profile
PurpLev
8536 posts in 3672 days
#1 posted 05-16-2013 08:52 PM
thats about right – for a console table I would put a top coat of lacquer for better protection (than shellac).
keep in mind, cherry can blotch, you may want to start with a conditioner or a blotch control coat first.
View nwbusa's profile
nwbusa
1021 posts in 2310 days
#2 posted 05-16-2013 08:52 PM
I’m no finishing expert, but I’ve had blotching issues before when finishing cherry with oils. Others have reported better luck by applying a washcoat of shellac to the bare wood, before applying the oil finish. Zinsser Sealcoat is an example, but any light cut of dewaxed shellac should work. Good luck and let us know how it turns out.
Edit—Purplev beat me to it!
-- John, BC, Canada
View Finisherman's profile
Finisherman
227 posts in 1873 days
#3 posted 05-16-2013 09:06 PM
First of all, you only need a preconditioner if you’re planning to stain your piece. Otherwise, you can just use the shellac or lacquer by itself. I believe that amber shellac and orange shellac might be about the same colour. If anything, the orange shellac could be a little bit darker than the amber. Have you considered using garnet shellac? Garnet shellac is much darker than orange or amber shellac. You’d have to buy the dry garnet shellac flakes from an outfit like Lee Valley tools and mix them with denatured alcohol, but this is fairly easy to do. Charles Neil has a video posted on youtube which explains the procedure for mixing shellac. Finally, you can apply lacquer over a thin coat of shellac, but the shellac should be of the dewaxed variety to avoid any possible adhesion problems. Zinsser seal coat is a ready-mixed solution of dewaxed shellac.
View crank49's profile
crank49
4032 posts in 2995 days
#4 posted 05-16-2013 10:23 PM
Don’t forget cherry darkens all by itself, well by itself with the sun’s help.
View Mark's profile
Mark
#5 posted 05-16-2013 11:23 PM
I thought the shellac was a sealer/conditioner?
Crank49, over here on the Wet Coast we don’t get a whole hellovalota sun.
-- Mark
Finisherman
#6 posted 05-16-2013 11:32 PM
Mark: It can be, if it’s applied as a thin solution. In that case, it’s known as a wash coat.
View sandhill's profile
sandhill
2128 posts in 3948 days
#7 posted 05-17-2013 03:02 AM
Charles Neil sells a blotch control. I have used it and can vouch for it.
View Moron's profile
Moron
5032 posts in 3917 days
#8 posted 05-17-2013 03:19 AM
what ever happened to getting a book and reading it
Moron
#9 posted 05-17-2013 03:20 AM
or at least read the can
Moron
#10 posted 05-17-2013 03:34 AM
tips
inconsistant and poor sanding techniques is the leading cause to fine finishing failure and the path to perfection is expensive or laborious, pick one or both, and their isn’t an “easy” trail, thus why they make plastic laminate so dont be lazy and start being anal about sanding
Nice thing about wood
it never lies
Moron
#11 posted 05-17-2013 03:41 AM
the “art” of sanding isnt taught on bandwidth
its taught with tears
lol
finishing is the prize
View Clint Searl's profile
Clint Searl
1533 posts in 2385 days
#12 posted 05-17-2013 02:24 PM
Sand it to 220, and shoot it with NC or acrylic lacquer. All else is superfluous.
