ebonizing advantages
Forum topic by mbs posted 05-16-2013 05:06 PM 1495 views 0 times favorited 9 replies Add to Favorites Watch
View mbs's profile
mbs
1656 posts in 2969 days
05-16-2013 05:06 PM
I need to make some pegs for my G&G furniture. I’ve been using ebony stain because I’m too cheap to pay for real ebony. Is there an advantage to ebonizing wood rather than staining it?
thanks,
-- Sorry the reply is so long. I didn't have time to write a short reply.
9 replies so far
View Finisherman's profile
Finisherman
227 posts in 1878 days
#1 posted 05-16-2013 09:18 PM
I’m not sure, but in reading what you wrote, I think that you may be a little bit confused regarding terminology. Ebonizing is the process by which another wood is made to look like ebony. Staining with a pigmented stain is just one way to ebonize wood. There are a number of other ways to ebonize wood that may work even better. You could use a waterborne dye to ebonize your pegs. Be aware, though, that black dyes often have a strong blue or green undertone. I think that your best bet would be to buy some india ink from a crafts store and use that like a stain. Finally, you could try adding the india ink directly to your stain or dye for a really rich, deep, ebony colour.
View kdc68's profile
kdc68
2658 posts in 2305 days
#2 posted 05-16-2013 09:23 PM
A traditional method
v
v
http://www.wwgoa.com/articles/projects/ebonizing-wood/
-- Measure "at least" twice and cut once
View yellabret's profile
yellabret
56 posts in 2231 days
#3 posted 05-16-2013 09:25 PM
if red oak is an option, i have had very good results “ebonizing” test pieces using the vinegar and steel wool trick. a bolt if steel wool in a pint jar overnight did very well, tho most directions i read called for 48 hours. i was too impatient, but it turned the red oak coal black in 5 minutes or less. try it, it costs next to nothing and is quick, and all you need is a 1” piece of dowel to test it.
View mbs's profile
mbs
#4 posted 05-16-2013 11:28 PM
FInisherman – I was referring to ebonizing as the steel wool / vinegar trick.
Thanks,
View Nicky's profile
Nicky
695 posts in 4120 days
#5 posted 05-16-2013 11:45 PM
Ebonizing the wood has the same effect as staining. It just another method of darkening the wood.
You should try the Ebonizing method and decide for yourself if its a better way.
Both methods only color the surface. The wood type you use for your plugs will make a difference in the results. Then it comes down to your personal taste in the finished product.
-- Nicky
View Don W's profile
Don W
18756 posts in 2596 days
#6 posted 05-17-2013 12:21 AM
I tried ebonizing on my last infill planes. I think it as a different texture than stain. Its a chemical reaction in the wood. Plus it just sounds cool. I have an ebonized infill. Who want a stained anything?
I agree with Nicky, you should try it and decide for yourself.
yellabret
#7 posted 05-17-2013 01:14 AM
needs to be a wood with high tannin content – hence red oak is best. tried it with other woods and got a puke gray. Don is right – it just sounds cool! ask anyone who has milled red oak for slabs like i have and they will tell you about the black areas around old nails. same iron-tannin reaction.
i made a “rocking labrador” out of maple, and tinted the eyes/nose to get the pigment of a yellow lab. later this year i plan on making another out of red oak and ebonizing it to be a black lab. i like this idea way better than stain and certainly not paint, as the grain will sill be evident.
kdc68
#8 posted 05-17-2013 01:20 AM
”i made a “rocking labrador” out of maple, and tinted the eyes/nose to get the pigment of a yellow lab”
Wow…excellent work yellabret
View mbs's profile
mbs
#9 posted 05-17-2013 02:22 AM
Based on the comments it sounds like personal preference without any distinct advantage depending on the type of wood.
Thanks,
MBS
