Router Bit Question
Forum topic by gfadvm posted 05-16-2013 01:56 AM 3317 views 0 times favorited 24 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2808 days
05-16-2013 01:56 AM
Most of my router bits are the purple Grizzly ones. If I replaced them with Whiteside or Freud bits, what differences would I notice immediately? I can buy a whole set of roundover bits from Grizz for what a single bit costs from Whiteside or Freud. Just trying to justify the upgrade.
Edit: I’m only talking about 1/4” shank bits, not large profile bits.
Thanks
24 replies so far
View Straightbowed's profile
Straightbowed
717 posts in 2416 days
#1 posted 05-16-2013 02:04 AM
big difference to me, more balanced smoother cut, but I like Grizzly router bits, but I love Whiteside
-- Stevo, work in tha city woodshop in the country
Straightbowed
#2 posted 05-16-2013 02:06 AM
Whiteside bits are the smoothest cuttin bit Ive used but I would like to try some Infinity heard they cut smooth also
View nomercadies's profile
nomercadies
589 posts in 2456 days
#3 posted 05-16-2013 02:07 AM
If anyone knows how Diablo bits fit into the comparison, I’d like to know that too. Thanks for asking GF.
-- Chance Four "Not Just a Second Chance"
View Mainiac Matt 's profile
Mainiac Matt
8345 posts in 2446 days
#4 posted 05-16-2013 02:10 AM
I don’t know Andy, but I can’t imagine that for hobby woodworking with simple fluted or round over bits that you will notice a huge difference.
I think the Grizzly bits are a pretty darn good value.
-- I yam what I yam and that's all what I yam
View kdc68's profile
kdc68
2687 posts in 2394 days
#5 posted 05-16-2013 02:15 AM
Good question…I own a few of the purple bits. They are supposed to be the higher grade carbide. They are even cheaper when you buy 3 or more. I own American Eagle bits too, which are considered high quality. Both the Grizzly purple and American Eagle have performed great IMO..
Looking forward to seeing what others will post
-- Measure "at least" twice and cut once
View vonhagen's profile
vonhagen
539 posts in 2482 days
#6 posted 05-16-2013 02:17 AM
stick with the cheapest ones, you will find no difference. i use mostly turn a knives, way cheaper than buying a whole new shank when the bit gets dull or chipped but these are mostly all pattern and morticing bits. also andy i bought a 300 600 grit dmt dia file to sharpen my small profile bits and they work great. the turn a knives run about 5 bucks each and i get 2 times the use out of them and just throw them away if they get chipped. tools today.com
-- no matter what size job big or small do a job right or don't do it at all.
117203 posts in 3695 days
#7 posted 05-16-2013 02:17 AM
Maybe it’s psychological because of there cost, but I think they cut much better. I would follow up buy saying that I would not replace all of your router bits to start ,just get one that you use the most and see what you think.
vonhagen
#8 posted 05-16-2013 02:41 AM
remember this andy that high speed tool steel cuts way smother than carbide but dulls faster. all the large profile moulder and shaper knives i make are high speed steel and i can throw the whole head in the grinder when they get dull and high speed steel is less prone to chipping. some carbides will chip by just touching any steel surface but cut like butter on poplar. as far as 1/4 inch shank bits go they are mostly a decent grade of carbide and made by cnc grinders and have to pass ul standards to get into the country i believe. lietz are the best bits imo but are only 1/2 inch drive and above. amana is good as well.
vonhagen
#9 posted 05-16-2013 02:42 AM
i agree with a1 jim
gfadvm
#10 posted 05-16-2013 02:53 AM
Thanks for the input. I think A1Jim wins the prize for best advice tonight:replace a frequently used bit and make my comparison. Thanks Jim.
That was just too common sense to occur to me!
View NiteWalker's profile
NiteWalker
2737 posts in 2694 days
#11 posted 05-16-2013 02:55 AM
Better quality bits stay sharper longer, are usually sharper to begin with (noticeable when cutting) and have more carbide for sharpenings.
View robert triplett's profile
robert triplett
1566 posts in 3222 days
#12 posted 05-16-2013 02:56 AM
Gee Andy, most of my router bits are Vermont American. Maybe that’s why I don’t use a router much! Not much help am I!! I do usually try to buy the better of 2 options if I can
Robert
-- Robert, so much inspiration here, and now time to work!!!
View longgone's profile
longgone
5688 posts in 3426 days
#13 posted 05-16-2013 03:25 AM
I have a mix of all sorts of bits…including whiteside, freud and others that I don’t even remember what brand they are. The frued quadra-cut bits do a great job on round overs and rarely ever burn especially since I always cut a bit shy of my desired results and then make a final light pass.
Whiteside are my favorites for the carbide spiral bits and the pattern bits.
I think it is best to try several brands and see what works best for what wood types you use.
View DocSavage45's profile
DocSavage45
8686 posts in 2960 days
#14 posted 05-16-2013 05:36 AM
Watched a Marc Adams training video today on routers. Pretty sharp guy. Has the biggest woodworking school in USA.
His advice was pretty logical but it requires comparison shopping. More carbide means more times you can sharpen them. The amount of metal backing the carbide is also a factor. His next comment was how refined is the edge? How well was it milled. Like a well honed chisel.
He mentioned that is how he compares high and low end bits at trade shows.
You would probably need to go to a Rockler or Woodcraft store to compare your favorite cutters.
I understand that Freud Bits are made in Italy if that moves you in any direction.
Report back on what you think?
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Boxguy's profile
Boxguy
2735 posts in 2385 days
#15 posted 05-16-2013 06:54 AM
According to Jim Heavy carbide scraps are remelted and then made into sheets that are in turn made into new bits. The cheaper bits are from the second, third, or fourth remelting. Carbide loses some quality with each re-melt.
The more expensive bits are cut from the first sheet. They last longer, and are better made if you look at them under a microscope.
I agree with A1 Jim. Buy a cheap big set and replace the ones you use most often with better quality bits. When they start to burn on cherry or maple it is probably time to replace them. 1/2 inch shanks will give you much better results.
-- Big Al in IN
