Iturra Bandrollers for the bandsaw
Forum topic by ScottKaye posted 05-15-2013 08:10 PM 7848 views 1 time favorited 13 replies Add to Favorites Watch
View ScottKaye's profile
ScottKaye
618 posts in 1915 days
05-15-2013 08:10 PM
Anyone ever use these rollers before as a direct replacement to stock factory guides or cool blocks? I read a review here and here and I like what I see. At half the cost of a Carter bearing conversion I am very tempted to get these. I guess my question is are they just as good as Carter bearings or somewhere in between Carter and cool blocks?
Thanks
Scott
-- "Nothing happens until you build it"
13 replies so far
View IrreverentJack's profile
IrreverentJack
727 posts in 2805 days
#1 posted 05-15-2013 09:34 PM
Scott, The Iturra Design Catalog will answer all your questions. Louis Iturra describes when his products perform better than others and when they don’t. No website that I know of. Call 904-642-2802. As of 2010 the catalog was free. -Jack
View Dan Lyke's profile
Dan Lyke
1519 posts in 4087 days
#2 posted 05-15-2013 10:09 PM
Seconding Jack on getting an Iturra catalog. I haven’t used the guides yet, but I learned more about bandsaws from that catalog than any other resource.
View tenontim's profile
tenontim
2131 posts in 3706 days
#3 posted 05-15-2013 10:16 PM
I’ve had the guides on my Jet 14” for about 7 years and have had no problems with them. Give an occasional shot of lubricant.
View MrUnix's profile
MrUnix
6574 posts in 2161 days
#4 posted 05-15-2013 10:16 PM
I’ve haven’t used the Iturra bandrollers, but I have used band saws with stock metal, cool blocks and carter guides. If there was any difference, it wasn’t noticeable, so in my mind it’s just a waste of money. Jim Mattson over at the Woodworkers Gazette did a comparison between the various guide blocks and came to about the same conclusion that I did; ”First off, most woodworkers with durable, tool steel blade guides needn’t lose any sleep over having any of these bearing replacements. If there are any advantages to the bearings, I couldn’t see them unless the bearings are quieter. I really didn’t notice.”
View Bill White's profile
Bill White
4901 posts in 3922 days
#5 posted 05-15-2013 10:35 PM
I used Cool Blocks for at least 15 yrs. In my estimation, they are a no-brainer as far as inexpensive, quiet, and accurate. I will replace the bearings on my new G0555LX with Cool Blocks soon.
Bill
-- bill@magraphics.us
View JAAune's profile
JAAune
1783 posts in 2279 days
#6 posted 05-16-2013 12:22 AM
Stay away from those roller bearing guides whether they are expensive Carters or a cheaper alternative. With a good blade that has a good weld joint, you can tune a bandsaw with standard blocks to cut a perfect, straight line. I’ve yet to see anyone accomplish the same with roller bearings. You couldn’t pay me to put those on my saws.
In fact, the people I’ve known that owned saws with roller guides ended up getting rid of them or delegating them to rough-cutting tasks only. I’ve got an old Powermatic with the fancy rollers and it’s very difficult to get it working well. If I get the bearings too close to the blade they wear out and start squealing. If I back them off the blade is no longer supported and the cut is sloppy.
That Powermatic is seldom used now since I was able to acquire a Delta that had cool blocks mounted on it. The Delta functions much better.
ScottKaye
#7 posted 05-16-2013 02:44 AM
Thanks all for all your comments.. Maybe a good set of cool blocks is all I need. And JAAune, I’ll be more than happy to take that Powermatic off your hands so you don’t have to acknowledge its presence in your shop!
JAAune
#8 posted 05-16-2013 03:41 AM
I might put it up for sale at some point but have been too busy lately to bother with it. My first option is to see if I can find a way to install guide blocks in the thing somehow. If there’s no cheap and easy way to do that it’ll likely end up on Craigslist and I’ll bring another Delta to occupy the space.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3547 days
#9 posted 05-16-2013 06:59 PM
I changed one of my older bandsaws from coolblocks to a complete new set of cheap imported guides top and bottom with wheeled bearings and have never looked back they work fine so I think like mr unix these are a basic gimmick.
View b2rtch's profile
b2rtch
4851 posts in 3010 days
#10 posted 05-16-2013 07:02 PM
I use cool blokc and I love them, I do not see the need to spend money for anything else
-- Bert
View Harry Montana's profile
Harry Montana
46 posts in 1957 days
#11 posted 05-16-2013 07:03 PM
there is something in your eye
-- With regards from Harry Montana http://www.hardydeck.com
b2rtch
#12 posted 05-16-2013 07:23 PM
Harry, you must have something in your eye too:
Like with any other company certain products we wish to promote while others don not seem to need additional promotion.
LoL
-- Bert
View David Kirtley's profile
David Kirtley
1286 posts in 2960 days
#13 posted 05-16-2013 09:36 PM
I have some on my saw. They work fine. Kind of noisy. No real complaints. Cool blocks are a wonderful product though.
