Delta 17-925 Drill Press Center Shaft Replacement
Forum topic by Deadeye posted 05-15-2013 07:01 PM 1058 views 0 times favorited 0 replies Add to Favorites Watch
View Deadeye's profile
Deadeye
36 posts in 1887 days
05-15-2013 07:01 PM
Topic tags/keywords: drill press
I have a Delta 17-925 Drill Press, and my center shaft broke between the cast iron housing for the bearing and the pulleys. I ordered a new shaft, but I could use some advice on replacing it. Specifically, getting the old broken shaft and bearings out of the cast iron housing, I tried to remove them, but could not. I removed the retaining ring and tried tapping it out to no avail.
Any help would be greatly appreciated -
Thank you -
-- Even if you are on the right track, you will get run over if you just sit there.
0 replies so far
