Taking apart glued box
Forum topic by Peteyb posted 05-15-2013 02:54 PM 1239 views 0 times favorited 7 replies Add to Favorites Watch
View Peteyb's profile
Peteyb
131 posts in 2581 days
05-15-2013 02:54 PM
I am needing to take the box on the far right out that is painted gray after the tall skinny one. I need to resize it as there is not enough clearance for the router that and the lift I am putting in. I used Titebond II glue so can I get a heat gun and heat it up to get it lose. I have never done this and unsure how I am supposed to do it.
7 replies so far
View muleskinner's profile
muleskinner
896 posts in 2463 days
#1 posted 05-15-2013 04:36 PM
I had a small box with splined miters I was working on the other day. On the last of eight cuts for the splines my jig shifted and I gouged the cut. I found that throwing it ~12 feet at a concrete wall was pretty effective in dissembling it.
Other than that, I got nothin’.
-- Visualize whirled peas
View ChefHDAN's profile
ChefHDAN
1067 posts in 2876 days
#2 posted 05-15-2013 04:59 PM
How long has the joint been curing? If you’re going to make it smaller Id say to cut it but it looks as though that is a single monolithic piece that would be very hard to get onto the saw.
View oldnovice's profile
oldnovice
6900 posts in 3394 days
#3 posted 05-15-2013 06:33 PM
Many of the woodworking glues are somewhat flexible but do not like quick short blows with a rubber mallet and that is how I take glued pieces apart. If there are dowels, splines, or biscuits involved it just takes a few more quick strikes.
Another approach is using “spreader” option on some clamps. This does take a little more work!
Peteyb
#4 posted 05-15-2013 07:47 PM
There are really 4 different boxes. They are no dowels, splines or biscuits holding them together. It just has woodworking glue on the bottom and on the side that it is near. I was hoping to keep the box so that I could shorten it and put it back together.
oldnovice
#5 posted 05-16-2013 12:08 AM
I think a quick blow or two, from the inside of the cabinet, with a rubber mallet as close to a joint as possible will do the trick.
I took apart a Euro style upper kitchen cabinet and it was dowelled too using that technique.
View NiteWalker's profile
NiteWalker
2737 posts in 2603 days
#6 posted 05-16-2013 12:49 AM
If it’s just butt joints and glue, a rubber/dead blow mallet will work fine to separate them. BTDT.
View Viktor's profile
Viktor
466 posts in 3445 days
#7 posted 05-16-2013 01:13 AM
“I used Titebond II glue so can I get a heat gun and heat it up to get it lose”
- Yes. Titebond will soften considerably when heated regardless how old it is. Skip the mallet, you’ll break it. Just heat, wiggle and pull.
