I need to make a square hole...
Forum topic by Jofa posted 05-15-2013 02:39 PM 2101 views 0 times favorited 19 replies Add to Favorites Watch
View Jofa's profile
Jofa
272 posts in 1806 days
05-15-2013 02:39 PM
On my pedalboard builds I typically include an IEC plug for power. The dimensions are 1” x 3/4”
I’ve labored through this many times with a drill, coping saw, chisel, dremel, etc.
I’m thinking a mortise chisel bit might do the trick but I don’t have a drill press.
Any suggestions? Thanks!
-- Thank you Lord for the passion and ability to make things from your creation.
19 replies so far
View Tennessee's profile
Tennessee
2862 posts in 2483 days
#1 posted 05-15-2013 02:44 PM
I’m going to guess you are working with plywood? There isn’t a lot of options to improve over a drill and chisel save for a mortising unit. But…you could use a bigger hole saw and simply clean out the corners, that would be what I would do. Hole saw on a drill and a sabre saw. Got a HF handy?
View PurpLev's profile
PurpLev
8534 posts in 3617 days
#2 posted 05-15-2013 02:47 PM
a drill press would leave a lot to be desired for something like this – they are not the best (mortise adapters aren’t all that great on those machines).
depending on how many of those you are making a good solution would be to have a custom made “mortise chisel” type punch. you can drill and remove the bulk material with a drill and drill bit, and then use the punch to clean and square off the hole on your lines in a single step (punch).
another solution is a router (in a router table) with a template bit and a template, that will leave the corners slightly rounded though which may or may not be an issue.
View Jofa's profile
Jofa
#3 posted 05-15-2013 02:48 PM
Thanks Vol!
I use a lot of different woods. Alder, clear pine, maple, mahogany and yes, plywood.
I love HF! They have a mortise chisel but I’m not sure if this can be used without a drill press.
http://www.harborfreight.com/12-mortising-bit-and-chisel-68679.html
View HorizontalMike's profile
HorizontalMike
7749 posts in 2882 days
#4 posted 05-15-2013 02:52 PM
A squarehole drill bit is the answer to this query, as noted in other posts on this. Not cheap, but you did ask… ;-)
10278 posts in 3616 days
#5 posted 05-15-2013 02:59 PM
You can use a hollow mortise chisel with a hammer
to square round-corners. You can also use a
corner chisel. Various styles are available.
For setting up to do this in a production way,
I recommend a template and a router so
the hole will always come out the same – the
router makes round corners of course but a
couple of minutes of work with a sharp chisel
squares them off.
The hole can also be mortised quickly with a
firmer chisel. With care this can be done
rather neatly.
View Fuzzy's profile
Fuzzy
298 posts in 3957 days
#6 posted 05-15-2013 03:13 PM
A Roto-Zip or Dremel type tool with a template would cut out nice, straight sides with only a swipe or two with a file needed to clean out the corners.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View junebug's profile
junebug
101 posts in 2373 days
#7 posted 05-15-2013 03:25 PM
have you tried a corner chisel? Hog out the majority of the material with a router or drill press
http://www.rockler.com/product.cfm?page=19422
View JustJoe's profile
JustJoe
1554 posts in 2007 days
#8 posted 05-15-2013 03:37 PM
You can use the mortise chisel thing without a drill press, just take out the drill bit and slap on a handle suitable for whopping with a mallet:
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View Don Broussard's profile
Don Broussard
3529 posts in 2220 days
#9 posted 05-15-2013 03:40 PM
@HMike—That squarehole drill bit is the first one I’ve seen. I thought at first that it was an April Fool’s Day tool from one of the big brand tool manufacturers. In the video, it looks like the chuck is wobbling quite a bit but it did cut a nice square hole in that piece of metal. The cutting pattern reminded me of my old Spirograph drawing toy. Thanks for posting that.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
View Don W's profile
Don W
18686 posts in 2536 days
#10 posted 05-15-2013 03:56 PM
if none of the above ideas fit, drill the hole and use a square file/rasp.
View ChefHDAN's profile
ChefHDAN
1057 posts in 2818 days
#11 posted 05-15-2013 05:08 PM
Also vote for the router if you use a 1/8” you would have a hardly noticeable rounded corner that would seem to me wouldn’t be an issue for your intended use
View mtenterprises's profile
mtenterprises
933 posts in 2661 days
#12 posted 05-15-2013 06:43 PM
Easiest way is to drill 1 small hole and use a scrollsaw, less than 5 minutes once you are set and ready.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View Jofa's profile
Jofa
#13 posted 05-15-2013 07:45 PM
Wow very helpful suggestions everybody.
That video was amazing!
HorizontalMike
#14 posted 05-15-2013 09:36 PM
Don,
It is real, those it surprises the HECK out of me how it works! Cool, but expensive….
View Dan Lyke's profile
Dan Lyke
1519 posts in 4093 days
#15 posted 05-15-2013 10:08 PM
1”x¾”? How thick is the stock you’re cutting through?
If I had to do a bunch of those, I’d build a square jig for the router with a guide bushing. If it’s ¼” ply use a 1/8” diameter bit, if it’s thicker use a ¼” diameter bit. Even in thicker stock, taking out a 1/16” or 1/8” radius corner becomes two hits on a chisel with a hammer (might not even have to clean the corners with the thicker bit…).
