Powermatic 66 Won't start
Forum topic by Hippockets posted 05-15-2013 03:01 AM 3135 views 0 times favorited 5 replies Add to Favorites Watch
View Hippockets's profile
Hippockets
93 posts in 2981 days
05-15-2013 03:01 AM
I have a 5 HP single phase 220 Powermatic 66 that won’t start with the start button. However it will start when I take the cover off and press the blue button. As a first step I replaced the Capacitors. That gave me the capability to start it with the cover off. The start button actually depresses to the right of the blue button
-- Bruce, Arnold MD bjordan443@aol.com
5 replies so far
View mrg's profile
mrg
793 posts in 2873 days
#1 posted 05-15-2013 03:14 AM
The blue must be a safety the way you are describing the symptom. Is there an actuator on the cover that depresses the blue button? Does the start button hit the white button or the blue?the blue looks like the start button should sit in the indent in the middle.
Can you click a pic of the back of the cover?
-- mrg
View muleskinner's profile
muleskinner
896 posts in 2311 days
#2 posted 05-15-2013 04:59 AM
Does the saw keep running after you push the blue button? The blue button is actually the magnetic starter contacts. Once you push it in it should also close the coil circuit and continue running until you press the stop button. If it doesn’t stay in, check the stop button contacts (with the power off of course). You should have continuity through the two red wires directly below the red button.
Edit – Oh, and try pressing the reset button.
-- Visualize whirled peas
9770 posts in 3522 days
#3 posted 05-15-2013 08:01 AM
Those magnetic starters aren’t expensive.
They are mechanical and very reliable, however
oxidation of contacts can occur over time.
Contacts inside which can be cleaned
with fine wet/dry sandpaper.
View REO's profile
REO
927 posts in 1948 days
#4 posted 05-15-2013 10:48 AM
the contacts below the red button you call out as number three should be closed they are labeled NC. these are the closed contacts of the start circuit. try pushing the blue button to the left of the red button #3. this is a reset for over load condition. if you had to replace the caps it probably overloaded trying to start previously. it depends on the contactor some times you have to turn the blue button and then restore the position to reset but most of the time just push it once.
View shopgirl21's profile
shopgirl21
1 post in 1644 days
#5 posted 07-22-2013 06:13 AM
I have the same issue with my “new” model 66. However, I tried pressing the blue reset button on the bottom right next to the stop switch ant it didn’t do anything. Is that reset button supposed to be flush with the housing? mine appears to be popped out.
I can get the saw going by pressing the blue button (#3) and holding for a few seconds but pressing the white start button(#1) only produces a humming noise while i hold the button in and does not turn the motor.
Any thoughts on the problem?
