Table Height / Bench Height Ratio of Awesomeness?
Forum topic by UncannyValleyWoods posted 05-14-2013 06:59 PM 36299 views 1 time favorited 10 replies Add to Favorites Watch
View UncannyValleyWoods's profile
UncannyValleyWoods
542 posts in 1859 days
05-14-2013 06:59 PM
Question: Finished a dining table, which from floor to table top is roughly 34inches… I’m building a corresponding bench. Right now, I’ve got the bench height set at about 18 inches. The height feels good to me, but I’m a bit frumpy, so I was wondering if this height would pose a challenge to others (too short/too high). Is there a standard ratio between table height and bench height?
-- “If Jesus had been killed twenty years ago, Catholic school children would be wearing little electric chairs around their necks instead of crosses.” ― Lenny Bruce
10 replies so far
10377 posts in 3643 days
#1 posted 05-14-2013 07:16 PM
I think 17” is standard chair seat height.
View crank49's profile
crank49
4030 posts in 2966 days
#2 posted 05-14-2013 07:46 PM
Isn’t 34” about 3 or 4 inches taller than normal?
UncannyValleyWoods
#3 posted 05-14-2013 08:09 PM
34” is a little taller than normal..but not much. 30 is the typical standard for a dining table. I went off of the dining table that we use in our kitchen and from the floor to the where the legs meet the table it’s 29 inches…with the thickness of the table top, it stands at about 31.
For the design of the table I built, 34 was just right.
UncannyValleyWoods
#4 posted 05-14-2013 08:12 PM
Correction: just went and measured the table height again…It’s firm at 32”...not sure where I got 34 from. *Reason #367,378 why I’m not a mathematician.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2067 days
#5 posted 05-14-2013 10:26 PM
For what it is worth… If you trust these people (the gubment) Here is a link to what the ADA has to say about it. But the magic ratio is 18” bench 30” table. They say 18” bench, and a range of 28 to 34” on table height, with 27” clear for knee space. Read here
-- Who is John Galt?
View DS's profile
DS
2916 posts in 2415 days
#6 posted 05-14-2013 11:21 PM
A typical dining table is between 29” and 31” height.
ADA says height cannot exceed 34”, then, there’s the “must have” clearences. (29”h at front, 27”h at 8” under the counter, 9”h at 6” from the back wall, etc, etc.)
I didn’t read where he’s building an ADA dining table, though.
The OP question is about chair seat height. I say if it feels good to you then it IS good.
UncannyValleyWoods
#7 posted 05-14-2013 11:24 PM
Thanks Joey. Looks like these guidelines were published during a Republican administration ;-) ..... Not sure if that makes them better or worse. I’ll have to consult my feng shui design book. ;-)
crank49
#8 posted 05-15-2013 02:53 AM
”Looks like these guidelines were published during a Republican administration ;-)”
That only means there probably is not a hidden tax involved to use the guidelines and there might not be any tree huggers or environmentalists getting kickbacks and grants for studying and verifying the information contained there-in. ;^)
View redSLED's profile
redSLED
790 posts in 1887 days
#9 posted 05-15-2013 03:18 AM
I’m with joey…in and DS on the table/seat height guidance.
For custom made tables, my height recommendations are:
- if the owner and their adult family and friends are 5’10” and taller on average – the table should be 30”-32”
- if the owner and their adult family and friends are 5’6”-5’10” on average – the table should be 28”-30”
For all table heights, general bench height should be 18” plus or minus a half inch.
One other minor consideration: any dinner table higher than 32” is too high for regular laptop use – assuming 18” high seat height.
joeyinsouthaustin
#10 posted 05-15-2013 02:16 PM
Thanks Joey. Looks like these guidelines were published during a Republican administration ;-).... . I’ll have to consult my feng shui design book. ;-)
Dem or Rep if it was published by a politician… you don’t need feng shui to know it was the year of the RAT. ;)
DS Op writes ” so I was wondering if this height would pose a challenge to others (too short/too high). Is there a standard ratio between table height and bench height?” And I thought it was an ok resourse to consult on the subject of what “others” needs might be. But in general… I agree with the statement ”if it feels good, it is good
Edit redSLED That is a good way to to pose the question of height to a client. I like that thinking on ranges.
