Hanging 100lb Heavy Bag from Ceiling 4x6 Tips
Forum topic by PatrickIrish posted 05-14-2013 04:25 AM 7622 views 1 time favorited 7 replies Add to Favorites Watch
View PatrickIrish's profile
PatrickIrish
131 posts in 2280 days
05-14-2013 04:25 AM
I have a 4×6 running left and right in the attic above my garage and want to hand a 100lb heavy bag.
Many use an eye bolt and go through the wood with a nut on top. I was trying to find an 10” eye bolt that was all threaded so I can put a nut and malleable washer on the top and bottom. Well finding an all threaded eye bolt is impossible or they run $30+ online.
Got any ideas?
My dad said to use this with four 3/8×2” lag bolts. I don’t like the idea of lag bolts. Will 4 of them hold a 100lb bag? I feel much more comfortable drilling through the beam with a nut on top.
I was also thinking about using one of these and drilling through the beam and use 8” long bolts with lock nuts.
Lastly, I could just get about 2ft of chain and wrap it around the beam.
My main concern is if lag screws are strong enough. I could use 4” long screws.
Thanks
Rc
7 replies so far
View LokisTyro's profile
LokisTyro
46 posts in 2097 days
#1 posted 05-14-2013 05:05 AM
Do what I do, hold the bag up with one hand and punch with the other :p
Get some structural screws?
-- -Andy ~~~~~~~ http://lumberjocks.com/projects/silent ~~~~~~~
TopamaxSurvivor
18422 posts in 3910 days
#2 posted 05-14-2013 06:31 AM
Lag bolts should do it, but I’d go with 3” instead of 2”. I hold mine with one hand and punch with the other too. Usually alternate back and forth so one arm doesn’t get a lot bigger than the other.
BTW, you could get all thread and cut it to length. Probably a lot cheaper than bolts long enough.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3148 days
#3 posted 05-14-2013 12:39 PM
I know this should already be understood, but since it has not been mentioned… Make sure you are hanging the ring on the vertical side of the beam. That way all of the weight of the bag is in shear/90* from gravity forces.
FWIW, the first ring looks like the better of the two because it has a better range of movement in than the second, and a welded ring is better for obvious reasons.
BTW, I use 4 of the first rings to hold my observatory dome in place against foul weather, and we have had several storms here in Texas in excess of 70mph winds trying to lift it off of its movable base. My 2-cents…
View Rex B's profile
Rex B
320 posts in 2485 days
#4 posted 05-14-2013 12:57 PM
McMaster Carr is a good source for heavy lift rated eye bolts. Looks like you can get one with 4.5” of thread for about $15.
In my opinion, 100 lb is not that much. I understand the inclination to overbuild things (I do it too), but I think either way would be fine. Lag screws are pretty darn strong in a solid wooden beam.
-- Rex
View Bluepine38's profile (online now)
Bluepine38
3380 posts in 3319 days
#5 posted 05-14-2013 02:24 PM
Second topo’s suggestion of allthread. Use a big washer and nut on top, and put a lifting eye on the bottom.
These should be available at a hardware store, or a fastener-nut & bolt- store near you and are available in
different grades or strengths.
-- As ever, Gus-the 80 yr young apprentice carpenter
View ChuckC's profile
ChuckC
843 posts in 3169 days
#6 posted 05-14-2013 02:32 PM
Lag screw’s from the box store will be more than enough.
View Mainiac Matt 's profile
Mainiac Matt
8609 posts in 2563 days
#7 posted 05-14-2013 03:12 PM
Just think how tough you’re going to feel when you knock the back off of it’s mount :^)
I second the opinion that four lag bolts in the first (chrome) ring will be plenty strong.
-- I yam what I yam and that's all what I yam
