Rikon 10-325 assembly - What am I doing wrong?
Forum topic by Marcus posted 05-14-2013 12:12 AM 1400 views 1 time favorited 5 replies Add to Favorites Watch
View Marcus's profile
Marcus
1163 posts in 2046 days
05-14-2013 12:12 AM
So finally got around to putting my new bandsaw together and have a bit of an issue with the table. Im hoping someone can point out the bonehead thing I’m doing.
I put the 90° bolt in the table like the instructions said. Mounted the table to the trunnions. It appears the table is about an inch too far forward though. The 90° bolt does not line up with the bolt as the instruction say, and the blade looks like its sitting way too far forward in the slot. I don’t see any way to adjust the trunnions, especially not to move it forward an inch. Any ideas?
5 replies so far
View gtbuzz's profile
gtbuzz
427 posts in 2468 days
#1 posted 05-14-2013 04:15 AM
The black piece in your photos the bolt in the table is supposed to contact… It swivels out of the way. You can move it a little to align with the bolt in the table. It allows you to tilt the table a little past 90 without losing your 90 setting. I just looked at my bandsaw and it doesn’t look like they line up in the middle of the frame, so that may be throwing you off.
Marcus
#2 posted 05-14-2013 11:31 AM
Thanks gt. I had to tap the little black piece with a hammer to get it to move, but everything looks like its good to go now.
View syenefarmer's profile
syenefarmer
492 posts in 3107 days
#3 posted 05-14-2013 08:50 PM
The position of the blade in your photo is correct so no problem there.
View Sandra's profile
Sandra
7207 posts in 2102 days
#4 posted 05-15-2013 12:48 AM
Not sure about the first picture, but the second one looks like the way mine is set up.
The instructions that came with my 10-325 were excruciatingly awful. A few times I just had to walk away.
I’m happy with it though, so good luck.
-- No, I don't want to buy the pink hammer.
Marcus
#5 posted 05-15-2013 12:12 PM
Thanks Sandra. I’ll agree, the instructions w/ the Rikon are pretty poor. Everything is put together and it just needs some fine tuning. The table is tilted forward about 5 degrees from the blade at this point. It was 100 degrees out yesterday, so didnt feel like tinkering with it in the garage.
