wood for work bench
Forum topic by pmelchman posted 05-13-2013 01:24 PM 2540 views 0 times favorited 16 replies Add to Favorites Watch
View pmelchman's profile
pmelchman
85 posts in 3116 days
05-13-2013 01:24 PM
what are the most ideal wood for work bench? what is not ideal? pros/cons opinions welcome input of any type.
pmelchman
-- Patrick https://www.facebook.com/dragonflywoodworking
16 replies so far
View MrFid's profile
MrFid
874 posts in 1866 days
#1 posted 05-13-2013 01:28 PM
Ideal: hard and heavy (maple, ash, mdf if you’re cheap like me)
Not ideal: tile, laminate, eggs, cardboard, etc.
-- Bailey F - Eastern Mass.
View Ripthorn's profile
Ripthorn
1454 posts in 2947 days
#2 posted 05-13-2013 01:29 PM
You could use all kinds of woods. Maple is a popular choice, as is doug fir and southern yellow pine (SYP). My bench is made entirely of doug fir and works quite well. For the base you could use whatever you want, and for the top, there seem to be two schools of thought: one is to use a softer wood so that it doesn’t damage your work piece, the other is to go with something good and hard to last a really long time. Either way you will need to periodically flatten your bench top (something I need to do….)
Smitty_Cabinetshop
15278 posts in 2580 days
#3 posted 05-13-2013 01:35 PM
http://en.wikipedia.org/wiki/Janka_hardness_test
- Hard is good (see link above)
- What you have access to is good; you’ll need plenty
- What you can afford is good; some parts of your bench will be bought (vices, dogs, etc., unless you do wedges. See Shipwright’s amazing bench and leg vise hear on LJs, for example)
I’ve seen benches of big box 2x material as well as LVL. Red and white oak, walnut and paduak too. Maple and cherry. If I were to build another, hickory is what I’d try to find. It’s nasty-tough, and heavy. So hard to work with, though.
My .02.
View bondogaposis's profile
bondogaposis
4680 posts in 2313 days
#4 posted 05-13-2013 01:40 PM
I’d use whatever you can get cheaply. Lots of folks have had good luck w/ SYP. I can’t get that here, so I used a combination of ash and poplar on mine.
-- Bondo Gaposis
View redSLED's profile
redSLED
790 posts in 1854 days
#5 posted 05-13-2013 03:14 PM
I believe most benches are built around decisions like the ones below instead of someone trying to identify an “ideal” wood. Also, in spite of rationalizations I think most folk in the end choose their wood based mostly on #6. overall for their beloved workbench.
1. Budget dependent
2. Length of build time (joining, gluing up exotic/hardwoods or screwing together 2×4s, MDF)
3. Copying existing popular bench designs showcasing certain woods vs. your own ‘hybrid’ design
4. Decision to use available reclaimed wood vs. just buying what you want
5. Your bench top will get a lot of heavy use – therefore hardwood top or at least hardwood edging with “sacrificial” (replaceable) MDF/hardboard/plywood top
6. Personal affinity for certain woods – maple vs. oak, pine vs douglas fir, etc.
7. Weight of bench perhaps (hard vs soft wood) – for mobility/transportability
View Brandon's profile
Brandon
4152 posts in 2913 days
#6 posted 05-13-2013 03:47 PM
What type of bench are you building?
Here’s a blog post I wrote when I was working on my bench: http://lumberjocks.com/BrandonW/blog/27563
-- "hold fast to that which is good"
View BubbaIBA's profile
BubbaIBA
387 posts in 2338 days
#7 posted 05-13-2013 03:52 PM
“what are the most ideal wood for work bench?...”
Depends. Are you building a work bench or a piece of furniture to show off your wood working skills. If it is a work bench go with heavy, cheap, and stiff. DF or SYP from the Big Box fits the bill very well. Around a $100 USD you can have the wood for a 24”X96” with base work bench. I built one 30 years ago with the thought that once I had a little more money I would build a “good” bench out of maple or birch. Never needed to, the SYP one is still working just fine and I built another one out of SYP last year that I expect will work as long as I have left.
View Kaleb the Swede's profile
Kaleb the Swede
1821 posts in 1931 days
#8 posted 05-13-2013 04:14 PM
I made mine out of all pallet wood, and recycled wood. Most of it was hardwood like maple and oak, that I found in pallets. It’s my first so I thought it would work great for a time. Ideal? If I had to do it again I would build one like Mr. Allan Little did on Askwoodman.com. I like the idea of a larger work surface. His top is a singe piece of 5×5 baltic birch. I’ll save the nice looking wood for furniture.
-- Just trying to build something beautiful
View PurpLev's profile
PurpLev
8534 posts in 3610 days
#9 posted 05-13-2013 05:17 PM
ideal = available locally and cheap. Of those that meet this statement, the harder the wood the better (while still remaining available and cheap that is). this could vary greatly depending on location. can be Maple, Birch, Oak, Beech, Yellow Southern Pine (SYP) or similar.
View MrRon's profile
MrRon
4709 posts in 3205 days
#10 posted 05-13-2013 06:05 PM
The top is the real concern. You can use any wood you like for the base, even plywood. I would stay away from MDF. Legs made of that stuff get easily damaged at the floor.
pmelchman
#11 posted 05-13-2013 06:53 PM
@ brandon,
I have decided on the 21st century workbench done by bob lang
View RonInOhio's profile
RonInOhio
721 posts in 2826 days
#12 posted 05-13-2013 06:57 PM
Ash is a good workbench wood. As is popular. Should be a little easier on the pocketbook
than maple.
If you wanted a hardwood top you could still build the frame out of a softer wood. Easier to mill,more
cost effective, etc.
Hardwood butcher block tops can be purchased if you want to avoid the hassle/time of glue-ups and hand planing your own top.
View sgmdwk's profile
sgmdwk
308 posts in 1835 days
#13 posted 05-13-2013 07:20 PM
I just finished a really solid bench with three layers of 3/4 inch oak plywood laminated for the top (horrors!). It is flat, heavy and was much cheaper and easier to make than building a traditional top with no bench to work on. In the future, if I have the inclination, I can use my current bench to build a new top for the really heavy, solid base I built.
-- Dave K.
View waho6o9's profile
waho6o9
8160 posts in 2539 days
#14 posted 05-13-2013 08:05 PM
http://www.grizzly.com/search/search?q=maple%20tops&cachebuster=2733885331545025
Grizzly has some nice ready made tops that are cost effective, all things considered.
View BentheViking's profile
BentheViking
1782 posts in 2526 days
#15 posted 05-14-2013 01:58 AM
When I build mine I’m going to use 2x for the frame, pallet wood for the shelf, and plywood topped with hickory flooring and hickory trim. I think that will give me the best balance of cost and durability.
-- It's made of wood. Real sturdy.--Chubbs Peterson
