Zero clearance for router table with big hole
Forum topic by savan posted 05-13-2013 02:00 AM 1306 views 0 times favorited 6 replies Add to Favorites Watch
View savan's profile
savan
97 posts in 2263 days
05-13-2013 02:00 AM
Does anyone know of a zero clearance in the table solution for a router table with an oversized hole in it?
I got a table like this one off CL and it’s got an oversized hole in the table. I’d like to have near zero clearance in the table top if i can…
http://www.sears.com/craftsman-router-table/p-00928160000P?PDP_REDIRECT=false&s_tnt=39869:4:0#reviewsWrap
View BacktotheWood's profile
BacktotheWood
125 posts in 2893 days
#1 posted 05-13-2013 03:37 AM
I got some pieces of plexiglass that were the right thickness and made several inserts with different inside holes for different size router bits. A 3/4” hole for small bits like a 1/4” straight bit, a 1-1/2” hole for mid-size bits, a 2-1/2” hole for larger bits and then no insert for the largest bits. Its worked out great.
Hope this helps.
-- Bob, --Silence & smile are two powerful tools. Smile is the way to solve many problems & Silence is the way to avoid many problems.
View NiteWalker's profile
NiteWalker
2736 posts in 2449 days
#2 posted 05-13-2013 01:43 PM
There’s a few ways to handle this. Probably what I would do is use a rabbeting bit to rabbet the existing hole so there’s a 1/8-1/4” lip maybe 1/4” deep, then make inserts to fit out of 1/4” plexiglass. You could make a master template out of mdf or plywood, then once that fits properly, make a bunch of inserts.
Shawn Masterson
1324 posts in 1820 days
#3 posted 05-13-2013 03:56 PM
I really see no reason to make it smaller, other that if you were running really small stock. witch is dangerous.
View Loren's profile
9764 posts in 3520 days
#4 posted 05-13-2013 04:02 PM
I agree with NiteWalker. When I built a simple router table
years ago, I cut a 1/4” deep x 3” square recess centered
on the hole. It’s simple to cut a square from masonite
and make a zero clearance insert anytime you need one –
cutting an accurate circular insert is more of a hassle and
of course the square one won’t turn in the recess.
Shawn Masterson
#5 posted 05-13-2013 06:56 PM
just be careful if you are using the table without the fence. I have seen the inserts get launched and ruin the bit.
NiteWalker
#6 posted 05-13-2013 08:22 PM
The square inserts work great; I have that setup at my drill press table, which I need to post soon.
