Spraying Zinsser bin shellac primer
Forum topic by Eric25 posted 05-12-2013 08:17 AM 3032 views 0 times favorited 3 replies Add to Favorites Watch
View Eric25's profile
Eric25
3 posts in 1807 days
05-12-2013 08:17 AM
Topic tags/keywords: zinnser spraying primer
I’ve made a built-in closet with drawers. Part plywood and part MDF. Is it safe to spray Zinsser bin shellac primer with a hvlp sprayer indoors?
3 replies so far
View kizerpea's profile
kizerpea
774 posts in 2333 days
#1 posted 05-12-2013 11:18 AM
good question…
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View Tkf's profile
Tkf
38 posts in 1893 days
#2 posted 05-12-2013 11:48 AM
Sure. But only with good ventilation.
View huff's profile
huff
2828 posts in 3251 days
#3 posted 05-12-2013 12:52 PM
Tkf + 1
You will also want to be aware of overspray. A lot of times we don’t pay as much attention when spraying clear finishes, but you will notice the white overspray will have a tendency to show up on everything. If you don’t have a way of setting up a small spray booth, then make sure you cover surrounding areas well and I usually like to have a fan pulling air directly from where I’m spraying (preferrably spraying directly in front of an open window or door with the fan pulling the overspray outside).
You may have to thin your product a little, but that will give you directions on the can and do you know what size tip you have in your spray gun?
-- John @ http://www.thehuffordfurnituregroup.com
