Removing dried PVA glue off of clamps?
Forum topic by mporter posted 05-11-2013 11:03 PM 6322 views 0 times favorited 10 replies Add to Favorites Watch
View mporter's profile
mporter
253 posts in 2577 days
05-11-2013 11:03 PM
Yes, I am the lone idiot that glued up a bunch of cutting boards without waxing my clamps first. They were brand new clamps, I was just too excited to make some boards I guess. Now the clamp bars are covered in dried PVA glue. Is there a good way to dissolve the glue without having to scrape it off? By the way i have tried to scrape the glue off and it looks like it is going to be about a ten hour job to get it done. Just looking for a lazy solution to this. I have about 45 glue covered parallel clamps. PLEASE HELP!!
10 replies so far
View NiteWalker's profile
NiteWalker
2737 posts in 2575 days
#1 posted 05-11-2013 11:09 PM
Brass wire wheel brush in a drill. A bit of heat from a heat gun or hair dryer speeds up the process.
mporter
#2 posted 05-11-2013 11:16 PM
Good idea, never thought of that.
mporter
#3 posted 05-11-2013 11:19 PM
I wonder if I can stick them in the oven first.
View Gary's profile
Gary
9331 posts in 3431 days
#4 posted 05-11-2013 11:58 PM
De-glu goo a product that melts the glue That’s it name. google it
NiteWalker
#5 posted 05-12-2013 06:31 AM
I wouldn’t stick them in the oven. The bars would probably be ok, not the handles or heads possibly.
View JoeinGa's profile
JoeinGa
7736 posts in 2006 days
#6 posted 05-12-2013 11:37 AM
After you get the glue off, try a piece of masking tape on each bar before using glue the next time. I like it better than wax.
View Monte Pittman's profile
Monte Pittman
29226 posts in 2337 days
#7 posted 05-12-2013 12:10 PM
I assure you that you are not the lone idiot on this kind of thing
View Matt Rogers's profile
Matt Rogers
109 posts in 1969 days
#8 posted 05-12-2013 01:03 PM
What about using a hot heat gun and just a hard plastic or metal scraper since PVA is a thermoplastic – meaning that it melts. You could also just blast it off with a propane torch. I can’t see the torch causing any damage to the thick bar of a parallel clamp because the glue would certainly melt at around 400 degree max and the bar will not have any metallurgical changes until at least 700. I also have lots of dried glue on my clamps (although I did wax them sometime in recent memory) and think that I may go out and try to clean them up right now.
-- Matt Rogers, http://www.cleanairwoodworks.com and http://www.cleanairyurts.com
View Bluepine38's profile
Bluepine38
3379 posts in 3084 days
#9 posted 05-12-2013 02:31 PM
Nearly all of my old pipe clamps have scrape marks from the putty knives removing glue until I discovered that
masking tape was not all that expensive and it pulls off real easy.
View JAAune's profile
JAAune
1798 posts in 2315 days
#10 posted 05-12-2013 08:03 PM
Hot vinegar softens PVA glues and causes them to peel away from the surface. I’ve actually used it once to reverse a glue up gone bad. I just put a little white vinegar into a cup then microwave it until it’s nice and hot.
