table saw blade problem
Forum topic by markv posted 05-11-2013 08:07 PM 834 views 0 times favorited 3 replies Add to Favorites Watch
View markv's profile
markv
5 posts in 2111 days
05-11-2013 08:07 PM
Hi,
I recently purchased a Ryobi BTS 20 portable table saw that came with a 24 tooth used blade. I decided to upgrade and first purchased a 60 tooth Irwin classic blade, and it wouldn’t rip 3/4 pine. I figured it was the saw and put the old blade back and it worked fine. I then purchased a hgh quality 50 tooth combination blade and that didn’t rip the pine either. I doubt I bought 2 defective blades does anybody have a clue to this problem.
3 replies so far
View Tedstor's profile
Tedstor
1643 posts in 2597 days
#1 posted 05-11-2013 08:09 PM
60 teeth is a very poor choice for rip cuts. 50 teeth is too fine too IMO.
On a tiny saw like the Ryobi, stick with 24 tooth blades when ripping.
Honestly, if I were ripping thinner stock (under 1”) on a small saw, I might buy a mid-grade circular saw blade in the 18-24 tooth range. I used a Freud 7.25” blade on my old Craftsman 8” saw and it worked great. And the blades are ~$10 at Home Depot.
markv
#2 posted 05-11-2013 08:21 PM
Thanks for the reply and quick response. Is that saw to weak to spin the blade fast enough to get good results.
View RibsBrisket4me's profile
RibsBrisket4me
1554 posts in 2470 days
#3 posted 05-11-2013 08:27 PM
Mark…no saw can do a great job ripping wood with a 50-60 tooth blade. That many teeth causes too much friction for efficient ripping.
When I rip I use a 24-30 tooth blade, and use a 40+ tooth blade for cross cuts. Also, think kerf blades are better for overall use on smaller saws, and when ripping makes sure your fence and blade guard/splitter are not binding during your cut.
