Forum topic by Matt Przybylski | posted 05-11-2013 06:25 PM | 1111 views | 2 times favorited | 11 replies | ![]() |
Topic tags/keywords: ridgid oss oscillating spindle sander I was using my ridgid oscillating spindle sander today for the first time using the spindles and I had the 1.5” on there. I was rounding off some 3/4” ply and I pushed it into the drum. To my surprise with what I consider relatively mild pressure the drum would come to a dead stop until I moved the piece back to take really light portions off. Is this normal? -- Matt, Arizona, http://www.reintroducing.com |
11 replies so far
#1 posted 05-11-2013 06:32 PM |
Matt, Did the drum itself stop spinning or could it have been the drum spinning inside the sanding sleeve. I have, a couple of times, not tightened the tensioning knob down quite enough and the drum actually spins inside the sleeve when I applied pressure against the sanding sleeve. ...just a thought. Best Regards. – Grandpa Len. Work Safely and have Fun. -- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana. |
#2 posted 05-11-2013 06:34 PM |
Yes, it was the sleeve not spinning but the drum spinning. How would I go about tightening the sleeve on the drum? -- Matt, Arizona, http://www.reintroducing.com |
#3 posted 05-11-2013 06:46 PM |
Matt, You slide the rubber drum onto the spindle, slide the sanding sleeve over the drum, put the proper sized washer on the threads at the top of the spindle and then thread the knob onto the top of the spindle and tighten the knob down onto the washer which applies pressure thru the washer and expands and compresses the rubber drum against the inside of the sleeve. If the sleeve still slips you may have to clean the sawdust off from the mating surface of the drum, a little soap and water should do the trick to restore the grip or friction to the surface of the rubber drum. Hope this solves your problem. Work Safely and don’t loose your grip. – Grandpa Len. ;-) -- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana. |
#4 posted 05-11-2013 06:48 PM |
Ah, I had overtightened the knob when I was using the belt and had to use pliers to help me get it off. Then as I read the instructions it said “don’t over tighten the knob” so it probably just scared me off and I left it too loose. I’ll tighten it down harder during next use but not to the point where I can’t get it off. Thanks GrandpaLen, as usual :) I sure love having you as a buddy. You’re always coming to my aide when I ask questions. It’s greatly appreciated. If you were closer to me I’d just hang out in your shop or mine and pick your brain all day :) -- Matt, Arizona, http://www.reintroducing.com |
#5 posted 05-11-2013 06:56 PM |
Matt – one time I neglected to put the correct washer on the bottom of the shaft before putting on the spindle – same problem with spinning. -- Any man can be a father, but it takes someone special to be a Dad |
#6 posted 05-11-2013 07:20 PM |
Matt—Taking the knob off can sometimes require assistance. I ran into that same problem so I made this little knob: I just slip it on when I need it and store it near the OSS in a drawer after Iʻve removed the knob. You can also use it to help you tighten the knob -- Tyvekboy -- Marietta, GA ………….. one can never be too organized |
#7 posted 05-11-2013 08:46 PM |
Great idea Tyvek. How did you cut out the inside? I have the same problem. -- Steve - "Never Give Up" |
#8 posted 05-11-2013 09:03 PM |
Matt, When I first started using mine, a few years back, I mostly used it with the Belt accessory and therefore left it mounted for the next time. -- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana. |
#9 posted 05-11-2013 10:13 PM |
I cut out the inside of the knob with my scroll saw. Donʻt you have a scroll saw? If not, you need to get one. I didnʻt know how much I was missing until I got mine. I got the Delta/DeWalt 20 inch scroll saw and it works great. -- Tyvekboy -- Marietta, GA ………….. one can never be too organized |
#10 posted 05-11-2013 11:12 PM |
@GrandpaLen: understood, I don’t use it enough right now because I’m in the middle of organization and every time I want to use it I have to whip it out, set it up, create room to put it, etc. my shop is a heaping mess right now but I have to finish a project I’ve been putting off far too long so that I can start on my shop projects next. @tyvekboy: great idea though I don’t have a scroll saw at the moment either. I guess for the time being ill stick to using the plier method :) -- Matt, Arizona, http://www.reintroducing.com |
#11 posted 05-11-2013 11:38 PM |
For the inside of the knob, you could always drill out 5 holes at each vertex of the star, and then use a coping saw to cut out the rest. |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4758 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8846 |
